Just installed a Stillway engine dampner
I'm not sure if I feel the improvement in shifting like everyone talks about? Nor do I feel the sturdiness that's talk about either? Maybe it's just me because I'm tired.
It was a easy install and everything fit fine. The only thing I disliked was the poor copies of the original instructions. It was very hard to see any diagrams of where the nuts / bolts went. It was also written Japanese.
= for instructions
They way it looks on my Evo doesn't look like how it's set-up on Gruppe-S's Evo?
I also don't like how the strut bar is uneven. The mounting plate that goes under the left side of the strut bar elevates it so the other side is slightly lower. You can't tell unless you are looking directly at it.
I will take it out later today, possibly the track if the rain holds off. I need this thing to work because I'm tired of buying radiators. I burnt the stock rad., and the engine / turbo put holes in a brand new Koyo. I have a DNP mani. we a 35R if your wondering. I'm now running a PWR and I can start to see where the turbo is actually flattening out some of the fins already. That's why I need this dampner to work, badly.
If anyone has one can you take a pic of how you have it setup? I'm not sure if I even have it on right... Thanks
= for instructions
My motor rocks forward, causing the turbo /wastegate/ fan to smash into and puncture the rad. Hopefully the dampner will stop the motor from moving / rocking so much.
This put three holes into my Koyo because of how thick it was and how little space I had. The PWR is a 37MM compared to the Koyo 57 MM (I think those #'s are right).
Originally Posted by skiracer
If you have an aftermarket IC, the radiator will be closer to the engine. So, it is possible for the engine to hit the radiator under hard braking conditions.
I never moved my radiator.
-Paul
my stillway did make a difference.
even when standing outside the car with the car started, when i rev the motor(throttle cable) i notice no rocking of the motor. Also, in the morning, my car has major clutch chatter that would shake my car very violently. Now it is not nearly as bad.
i was confused on the install also. And i was missing one of those bigger washer things.
I'm glad it made a difference because I was looking into buying a damper to help with shifting but if it's pointless then why spend the $$$$.
Anyone with pictures of it on the car???
Maybe I have mine in backwards. Do you think it matters which way it's in there?
Also do you have pics?
Originally Posted by PVD04
An aftermarket IC has no effect on the location of the radiator. An aftermarket radiator, however, is thicker than the stock radiator reducing clearance between the radiator and the turbo/exhaust manifold.
-Paul
-Paul
Sounds like you need one of these
I'm still waiting to see some longterm effects on these engine dampners..... you would think they would put more stress on the drivetrain?
