RPS carbon/carbon rattles, need advise
#31
Originally Posted by 94AWDcoupe
I can confirm the decell noises are normal for twin plate clutches. I have tried four different twin plate clutches in my car. They all have the decell noise. Heavier fly will not help. I run a 16 lb near stock weight fly, and noise is still there. Whats needed is the spring center on the disc. The only one on the market is the HKS. Not a very good clutch. And the spring center does not hold up to the power. I am building a driveshaft with a flex disc to solve the problem with my car. I dont care for the noise at all.
The sound is the transmission noise coming through the clutch because it doesn't have a sprung hub. That's what Rob told me at RPS.
It's much the same effect you get with an engine dampner. The noise transmits into the cabin because there's nothing to stop it.
You can always put the car in neutral or push in the clutch to minimise the sound.
#33
It is not necessarily a problem since it is not hurting anything (except your ears), but rather a tradeoff. There are benefits and tradeoffs with every design. In this case you have the benefit of a lighter disc that will potentially shift better and never have a center come apart. But the tradeoff of the noise. IMO, probably not what you would want on the street, but better for the track.
#34
I appreciate your advice. Its been a few weeks and the noise isn't bothering me as much as before. Its still harsh, but knowing its another sound of speed makes it a different catagory and so not as painful...now I just need help justifying the price tag!
Anyway, thanks again.
ct9a gsr
Apr 6, 2019 11:00 AM
WTT[MidWest]: Gauging interest/WTT RPS carbon-carbon EVO 8 clutch
powerdriver
May 23, 2016 09:16 AM
510Finn
52
Apr 26, 2016 12:08 PM
LogicPerformanc
187
Nov 18, 2005 11:31 AM
WRX EVOlution
12
Mar 11, 2005 01:13 PM
