Does intake do more harm than good?
I think a majority of the gains are with the less restrictive filter, I think the best bang for the buck is the panel filter to the stock airbox. All of my data indicates that the stock airbox really isn't a restriction, and as mentioned earlier, you have to be moving ALOT of air for the airbox to become a restriction. I do have reservations on the snorkle inlet as the only air source of the stock airbox, but there are remedies for that..
Such as...?
Originally Posted by gsujeff55
Well, i do have a buschur MAF pipe, but not looking at my car right now im not sure if i have the one bend or two bender.
so, the positioning of the maf itself doesn't matter then???
The positioning of the maf itself doesn't affect how the maf works for the most part, it really is positioned the way it is to prevent dirt from getting into it. The MAF is also very vibration sensitive, so as long as its anchored and doesn't bounce around, it really shouldn't matter. I have never done any testing with the orientation of the MAF so I don't have any personal experience with what it would do though.
It really is only subject to the turbulent airflow that it can get.. Anything you can do to reduce turbulent airflow through the metered portion of the sensor, should help reduce stalling and anomolous readings which could lead to drivability problems.
Originally Posted by Jeff_Jeske
I now the intake pipe made nice difference on my 98 GSX but the EVO isn't nearly as restricted as those DSMs were. Sure make the spool sound nice.....does just a conical filter increase the sound of the DV and spool?
l8r)
Originally Posted by Ludikraut
Even a panel filter on the stock airbox will allow you to hear more of your turbo and DV.
l8r)
l8r)
if you take the top off you will hear it all...
its pretty easy to make a contraption to hold the filter down around the edges.
Not in my experience. I hear next to nothing with my K&N panel filter. Just a slight spoolup sound and no BOV purge, although others outside the car can hear a slight, quick purge noise from my MR DV.
