Does intake do more harm than good?
#31
more horsepower or not, I still can't see putting a jiggly cone filter in my engine bay sucking in hot air in place of a factory cold air intake snorkeling directly from the high-pressure cool air from the front of the car.
#32
Originally Posted by MalibuJack
I spotted Monster Sport makes a replacement cover out of carbon fiber that looks to flow a bit more, and you can make, or purchase a simple frame to replace the top cover to expose the filter.. I still have the stock snorkle from the old airbox attached under my hood, it ducts air over the cone filter I run.. Not the optimum solution by any means, but its better than nothing.
#33
Not to hi-jack this thread but when you guys say you need "tuning" for the MAF pipe.. are you just talking about adjusting the a/f ratio's or something more in depth? I'm asking because as of right now I've only got a s-afc2 + wideband.. which gives me very little for tuning options.
I'm running the Works drop-in which seems to perform a little better than the k&n I had before.
#34
I actually happen to agree with you.. My circumstances necessitated losing the stock airbox, otherwise I would still be using it even without a MAF..
#35
Not in my experience. I hear next to nothing with my K&N panel filter. Just a slight spoolup sound and no BOV purge, although others outside the car can hear a slight, quick purge noise from my MR DV.
My turbo was noticeably louder. Can't speak to the stock DV(s), since I run a Greddy Type-S.
l8r)
#37
#38
I changed mine from stock to blitz sus power filter. I was worried about sucking hot air. But I saw few gain even with same air flow setting( I am using super afc to tune). I guess sucking hot air is better than stock restriction.
#39
Galante
Apr 2, 2015 08:41 AM
[WTB] cam Intake 272 or 264
patryko
Sep 11, 2014 02:52 PM
WTB[Northeast]: Ported Intake Manifold and Throttle Body
12WWGSR91
Jul 8, 2014 07:56 AM
