is my clutch going out?????
i did a little reading on the forums.... and it says that 4th gear at 7000rpm in our car should do around 110mph..... my car only goes about 96mph when i redline 4th gear.... is my clutch going out???? i have buschur stage 3 w/out the cams....... and i have only launched the car once.... that was like the first week i got the car..... is my clutch going out already???? or maybe it's something else.... any help would be greatly appreciated
Originally Posted by gsujeff55
do you have a 5spd or 6spd?
At 40mph, put it in 5th gear (or 6th) and floor it. When the boost starts to hit, if your car grabs and continues to build boost while pulling, then you're fine. If the rpms jump up as soon as boost hits, but you don't really move forward much...and then the rpms catch and drop back down, your clutch is slipping.
he didn't say redline, he said 7k rpms. im not sure what 4th is on a 5spd at 7k, but i know its about 122 at 7600.
i would venture to say this guy has a MR and nothing is wrong.....if you can't tell your rpms are rising and your car isn't going any faster...PLEASE sell your car to me for cheap cheap
damn, i just looked at the first part where he said 7k.
but, in actuality, redlining our car technically is 7k...because that is the redline on the tack....
rev limit, however...is a different thing. we are on the same page here....
im digging if you can't tell....LOL
i don't have a MR... it's a 2003 5spd......sorry about all the confusion....when i say redline.... i mean 7K rpm..... thanks for the replies so far
It's really easy to tell if your clutch is slipping. Just floor it and if the rpm needle goes up really quick but your car isnt pulling then its slipping. Also if you do this you might smell your clutch burning.
i have a SAFC2 with buschur settings..... i never really noticed this until i put in my buschur stage 2 and 3 parts..... maybe it's the new found power that's making it slip a little????
nope, if your clutch was slipping, you would build a lot of boost fast....but the car wouldn't really go anywhere because it would be like you had the clutch pedal pressed in.
to tell if your clutch is slipping, punch it and watch the RPMs, if they go up fast, but the car doesn't accelerate fast then the RPMs drop back down, your clutch is slipping.
