20G turbo upgrade from Buschur Racing.
#242
well i hate to sound like a straight noob but when you dont know sometimes you just gotta ask right well here goes
what does dave mean when he says the turbo was surging what does this feel like when you are driving
thnaks in advance
thnaks in advance
#243
for the guy who was asking how surging feels...
Originally Posted by davidbuschur
We pull out of the parking lot and it looks like he is already impressed. We start out of town and I don't know what he is doing at this point as the car is jerking and bucking and compressor surging, I say, "Damn, what are you doing?! This car has never done this before." He says, " I don't drive just at WOT, I have to modulate the throttle in boost in a corner." I am thinking, "WTF is going on, this is horrible." He drives it for 10 miles or so and says how impressed he is with how fast the car is, but the compressor surge isn't goign to cut it.
You know guys, I have let probably 6 guys drive this car since the 20G has been on it and nobody has had it surge. It is something to do with the technique of this high boost-part throttle driving style of a road racer. This turbo is NOT going to work if that is how you drive. Very odd.
#244
Super Street article on turbo sizing
Turbodriven.com explains compressor wheels and surge lines
The turbo regal website explains compressor sizing
Originally Posted by gnttype.org
"To the left of the envelope, where it is marked "surge limit", the flow through the compressor is unstable and will go up and down and backwards unpredictably. This is surging. Do not pick a turbo that will operate in this area! It can be very damaging."
Originally Posted by lextreme.com
"The Bypass Valve
Compressor surge is a problem that affects most superchargers and develops when the supercharger is creating boost, but the throttle shaft is closed. Although not a problem on some low-boost (5psi or less) applications This condition can occur under deceleration or while shifting between gears, and can cause the car to sputter and chirp. Under surge, the compressor forces air into the closed throttle body until the pressure inside the throttle body is higher than the amount of pressure being created by the supercharger, and the air tries to pop backward through the supercharger. At that point, pressure is released inside the throttle body and the compressor forces air back through the supercharger and into the throttle body, which again has nowhere to go, and the process repeats. While surge normally is not highly damaging to the engine it is certainly annoying and can cause damage with time. To eliminate these problems under surge conditions, a bypass valve (sometimes called an anti-surge valve) is used to release the excess pressure. The bypass valve is actuated using intake manifold vacuum, which opens the vent valve and releases pressure in the air-intake. Air is either released into the atmosphere (blowoff valve) or recirculated back through the supercharger compressor (bypass valve)."
Basically, surge happens when you're trying to force airflow into something that can't accept it (like high boost on partial throttle on a 2.0L motor). There are no real ways to prevent this other than decreasing the amount of boost requested in that partial throttle situation or increasing displacement in order to find a place for this airflow to go.
I like option #2.
#245
OK, 17 degrees is better, still getting up there for pump gas.
The 20G, if you already have a 10.5 is $800.
David Buschur
www.buschurracing.com
David Buschur
#247
The 20G's are on the way here now. As soon as they show up I will ship them. I have not tried a 20G with alky/pump gas yet. Yes, you can spray a 50 shot with the turbo or run alky/pump and the 50.
David Buschur
David Buschur
#249
I am running the stiffest spring in the Tial BOV that I could get.
#250
I get that sort of part throttle high boost misbehavior on my car but I attribute it to the BOV, not the turbo. I'm thinking of fixing my warped BOV flange (right now I have a Forge 1G sealed down with RTV) and then switching back and forth between the 1G DSM valve (daily driving/autocross) and the Forge (max straight line power) as needed. I did an autocross a couple of weeks ago and the surging was really a problem in the first couple of 1st gear corners. I had a very hard time driving part throttle at 3000-6000 rpm without the bucking and fluttering nonsense. It tended to make me want to floor it or lift completely to smooth things out, neither of which was good for times.
#253
Here is my timing map for the WR on the UTEC. There is no knock whatsoever. If you are running a UTEC use my map at your own risk.
Timing Map
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [15.5] [13.5] [13.3] [12.8] [11.3] [11.3] [11.3] [11.3] [11.3] [11.3]
[-100] [15.1] [12.1] [11.9] [11.4] [9.9] [9.9] [9.9] [9.9] [9.9] [9.9]
[-100] [14.1] [11.1] [10.9] [10.4] [8.9] [8.9] [8.9] [8.9] [8.9] [8.9]
[-100] [11.2] [11.1] [11] [10.8] [10.7] [10.6] [10.5] [10.3] [10.2] [10.1]
[-100] [12.4] [12.3] [12.1] [12] [11.8] [11.7] [11.6] [11.4] [11.3] [11.2]
[-100] [11.3] [11.2] [11] [10.9] [10.8] [10.7] [10.5] [10.4] [10.3] [10.2]
[-100] [9.8] [9.7] [9.6] [9.5] [9.4] [9.3] [9.2] [9.1] [9] [8.9]
[-100] [7] [6.9] [6.9] [6.8] [6.7] [6.6] [6.6] [6.5] [6.4] [6.4]
[-100] [4.6] [4.6] [4.5] [4.5] [4.4] [4.4] [4.3] [4.3] [4.2] [4.2]
[-100] [4.3] [4.3] [4.3] [4.2] [4.2] [4.1] [4.1] [4] [4] [4]
[-100] [4.7] [4.6] [4.6] [4.6] [4.5] [4.5] [4.4] [4.4] [4.3] [4.3]
[-100] [5.4] [5.4] [5.3] [5.2] [5.2] [5.1] [5.1] [5] [5] [4.9]
[-100] [6.1] [6] [6] [5.9] [5.8] [5.8] [5.7] [5.7] [5.6] [5.5]
[-100] [7.5] [7.5] [7.4] [7.3] [7.2] [7.1] [7.1] [7] [6.9] [6.8]
[-100] [7.7] [7.6] [7.6] [7.5] [7.4] [7.3] [7.2] [7.2] [7.1] [7]
[-100] [7.8] [7.7] [7.7] [7.6] [7.5] [7.4] [7.3] [7.3] [7.2] [7.1]
[-100] [8.2] [8.2] [8.1] [8] [7.9] [7.8] [7.7] [7.6] [7.6] [7.5]
[-100] [10] [9.9] [9.8] [9.7] [9.6] [9.5] [9.4] [9.3] [9.2] [9.1]
[-100] [11.2] [11.1] [11] [10.8] [10.7] [10.6] [10.5] [10.4] [10.2] [10.1]
[-100] [14.6] [14.4] [14.3] [14.1] [14] [13.8] [13.6] [13.5] [13.3] [13.2]
[-100] [17] [16.8] [16.6] [16.5] [16.3] [16.1] [15.9] [15.7] [15.5] [15.4]
[-100] [18.7] [18.5] [18.3] [18.1] [17.9] [17.7] [17.5] [17.3] [17.1] [16.9]
[-100] [22] [21.8] [21.6] [21.3] [21.1] [20.8] [20.6] [20.4] [20.1] [19.9]
[-100] [23.9] [23.6] [23.4] [23.1] [22.8] [22.6] [22.3] [22] [21.8] [21.5]
[-100] [24.3] [24] [23.7] [23.5] [23.2] [22.9] [22.7] [22.4] [22.1] [21.9]
Timing Map
#254
Timing Map
Timing Map
What you have typed looks like egyptian heiroglifics (sp?) to me
#255
David Buschur
David Buschur
cuz what i seen is tuning done wit an aem ems or alky. i just would like to see some pump and race oct number comparisons done by u. to truly see the difference between all these turbos and see what numbers are under the curve and hold to redline.
so if u can show us something that would be greatly appreciated.
i hope u read this cuz this is the 3rd or 4th time i ask and havent seen a response yet.
