20G turbo upgrade from Buschur Racing.
#317
Originally Posted by memo3
This would be little late to the topic but I was actually in Dave's car before the shootout. The white one of course with 20G and there was 3 people in the car including me (I weigh about 250lbs) so do the math. I have a Stage4 car that I drive daily. All I can say is, this 20g is a very big difference when you compare it to stock turbo/stage4. It has a lot more top end and kicks in just like stock.
That day, the boost around 25psi was holding very steady and it spooled very identical to stock, you can't tell if it is stock or not until the boost hits and pulls like a plane, that's where you say woow..
#318
Originally Posted by bpclements
Autozone sells the Permatex Anti-seize compound.
#319
Permatex (spelling) makes a copper anti-size thats good til like 1800f. I used the same stuff on my brakes with no probs
Item # 09128
Now I need to find something with a good heat rating to seal my downpipe. I found some Permatex silicone but it's only good to 650f
Item # 09128
#320
Item # 09128
Item # 09128
#323
Item # 09128
Item # 09128
Keith
#325
Malibu,
Been seeing many many cars come through here on our dyno. One thing the headers all have in common, a huge loss in low end power! I think every car I have dyno'd with a stock replacement header has taken a good 30 whp/ft lb of torque hit in the mid range over the stock ported manifold.
David Buschur
www.buschurracing.com
David Buschur
#327
header
or mine for that matter. When I installed my headers, I noticed a significant increase in low/mid range power. A LOT. Top end was not changed much or just not as noticeable.
Sigfrid
Sigfrid
#328
I think it depends on the runner size.. many of the headers I've seen have huge runners which lowers exhaust velocity..
I tend to agree with Dave though about losing some torque if you have large tube headers, especially if their not "tuned" appropriately for the turbo size (which most aren't)
