20G turbo upgrade from Buschur Racing.
#32
Originally Posted by gsujeff55
OK, im confused. I know this isn't the topic of the thread, but interesting none the less.
how would that make the boost gauge off then? Are you saying that the turbo puts out different boost levels in different weather and the boost gauge doesn't recognize it?
#34
That description of boost guage operation sounds like the way an altimeter works in an airplane, it needs to be calibrated "set to zero" to the altitude of the airport or dialed in using the currnet pressure.
#35
so, you are saying that the boost gauge is off because its not actually at 0 due to atmostpheric pressure.
what im saying is, my boost gauge was spot on with the DD sensor at the dyno....and i haven't changed the boost and the boost gauge doesn't show anything drastically different at peak or redline....nothing like 5 psi like dave is talking about.
again, maybe im still misunderstanding
#38
-Paul
#40
Well, my questions and posts are 100% on topic.....
your comment however(and mine in this post) are 100% off topic. keep peanut gallery comments to yourself.
#44
Great job David, Maybe I should upgrade to one of these from my current setup(cause she only runs 126.4 mph in the quarter)
#45
Yay 20g, I've been looking forward to this for a long time... I don't want a big huge turbo, but I'd like a bigger quicker one like the 20g and if that doesn't happen I'll just get a quicker one and get the TME.
