20G turbo upgrade from Buschur Racing.
#79
Originally Posted by gsujeff55
Thanks al. Just wondering.
I dunno how familiar you are with the xede.....but im currently running the timing table zeroed out with 25psi falling to 22psi(in 3rd gear). Any room to add more boost?
With the alcohol you can usually run as much boost as the stock turbo will hold - seems that you are prob close to that mark already if its holding 22
#82
I agree with the turbine wheel sizing. That is one of the things I addressed with our 20G and that is why we modify the turbine wheel by clipping it.
David Buschur
www.buschurracing.com
David Buschur
#84
IF I had the logs you would see them posted.
The turbo is a direct bolt on. I would suggest having some other modifications before just bolting it on. There are a bunch of other mods you can do that will give you more power than just bolting a turbo to a "stock" EVO.
Weather looks good for tonight, hope to get the car to the track.
David Buschur
David Buschur
#85
Here is the AEM EMS log for those of you dieing to see it (widebandphillip!haha).
I did this pull on the way to work this morning. Started from a slow roll in 1st and ran it to 130 mph in 4th.
David Buschur
David Buschur
#86
The forum will not allow the file to be loaded. Has to be formatted to a jpeg or something. If I do that you guys can't use your AEM software to view it. I am going to print it, scan it and then post it.
David Buschur
David Buschur
#87
David Buschur
David Buschur
#88
You know I don't want to make prediction but as anyone knows with the stock turbo the cars still pull at 120 mph but they don't pull HARD. This morning the car pulled HARD as a matter of fact I didn't realize I was at 130 mph as it was just hauling butt to 7500 rpm in 4th. This was at only 22-23 psi of boost. The boost was higher than that before with the stock turbo but not at 7500 rpm, so this turbo is VERY impressive. I don't know what it will run at this boost level but I think it is going to be pretty darn good. I'll turn it up after the first run or two.
David Buschur
David Buschur
