ACT clutch with flywheel?
How many of you used the stock flywheel or purchased a after market one? Just trying to get some opinions on those that run with or without it. Is it it worth upgrading to a better flywheel or the stock one is good enough.
Thanks
Thanks
We'll see what happens...
There was an article in either sport compact or Super Street I can't remember which, but it said that the stock flywheel does not dissapate the heat very well, which leads to premature clutch failure. When I upgraded I went with an ACT street disc and a fidanza flywheel, and I am very happy with that combination!
I just put in an ACT clutch and Prostreet flywheel. I went with the flywheel because since the clutch was coming out, might as well change the flywheel so I don't have to pull the clutch twice. But I've been getting a CEL and I think its because of the lighter flywheel, I have to confirm that though.
And since the cost of a new l/w flywheel is so cheap why not upgrade all at once.
New fw
Originally Posted by Taimur
No. L/W flywheels do not throw a CEL.
...This may turn out to be a bad thing, because when my stock clutch went out, it wasn't the clutch disk that was gone...it was the flywheel and pressure plate...
there really is no reason why you could not resurface the stock, unless it was so mangled that replacement is the only option. Even then, the new stock one from Mitsubishi is not overly expensive
Adam
Originally Posted by ACTman
??? How you destroy a pressure plate and flywheel and not hurt the disc?? I would like to see what you are talking about.
They threw all the parts away before I could take pics and show everyone. The flywheel and PP were both mirrors basically, but the disk had about half it's thickness remaining. IT was scarred, but not worn down all the way...
