TRE tranny
#31
Originally Posted by GOKOU
$675 Considering the drive/gas/mileage It might be better off letting a known shop take it off and send it in instead.
THanks for the info.
They are going by the books not what a EVO shop can do it for.
Jon@TRE
#32
Originally Posted by Yaroslav
All transmissions include the modified double synchro 2nd gear, improved HD 3rd/4th gear synchros, Center diff bearing upgrade, shot peened gears and improved oiling passages. All gears are wet-magnafluxed and installed inside a nice glass beaded transmission case and have a 120 day warranty.
Jon what does it mean?
Just believe what you wrote.......
If you mentioned i just asked you
You've just quoted something from the remanufactured DSM tranmission which has nothing to do with the EVO transmission or this forum.
You need to go to this page, http://www.teamrip.com/Evolution.html
NEW TRE-SPEC EVO-8 TRANSMISSION
$2650 with FREE SHIPPING. We our proud to introduce the latest effort in our line of performance transmissions. Again, TRE takes a factory new trans and modifies the gearsets to make them stronger, shift better and last longer. The end result is a much stronger transmission with improved shift quality that will last. This is a excellent transmission for those making serious power and shifting at insane rpms. Transmission includes the latest revisions and TSB's. If you are serious about your EVO you need this transmission, it allows you to drive the car the way it was meant to be driven.
Includes: throw-out bearing, clutch fork, slave cylinder and pulse generator.
Call or email for details.
Hope that makes sense.
Jon
#33
Jon@TRE
http://www.teamrip.com/transship.html
#34
I had my 2g dsm awd tranny rebuild by tre.Stock trans only held up for 3 launches at 5k rpm w/atc 2600.I can launch the tre trans all day.Probably over 100 launches on it and no problems at all.Very happy with my purchase.
