Leaking Transfercase/Transmission seal
Old Aug 1, 2005, 08:10 PM
Compjoc's Avatar
There is 1 seal and 2 o-rings that need to be there to stop the T-case from leaking. I've been in the same boat as you with my t-case leaking. 4 failed fixes at the dealership later, i decided to do it myself. I found the Dumba$$ dealer resorted to gasket maker to try to stop the leaking. I found they never put the little o-ring in.
Pics below - check out all the gasket maker crap, some got into my fluid.
Attached Thumbnails Leaking Transfercase/Transmission seal-tranny.jpg   Leaking Transfercase/Transmission seal-transfer-case.jpg
Old Aug 1, 2005, 08:21 PM
Tsurara's Avatar
****. I am going to be sure to say NOT TO USE that ****.
My repair slip last time listed the following as replaced:
T/F Sub Assembly
Oil Seal, T/F Case
O-Ring, T/F Case
Oil Seal, T/M FR DIFF CA
Old Aug 1, 2005, 08:35 PM
cliffsevo8's Avatar
yeah me too...so do you guys think i should go back and have them check it? he said if it where coverd the 90.00 serv chg will be add to warrenty if not then i would have to pay
Old Aug 1, 2005, 08:47 PM
lookEVO's Avatar
cant hurt. if they took it out though it shouldnt be your fault... i did read that they did work?
Old Aug 1, 2005, 10:40 PM
cliffsevo8's Avatar
how long did it take to get it fixed once in the shop?
Old Aug 1, 2005, 10:47 PM
Compjoc's Avatar
They could do it in 1/2 day if they had the parts. If they have to order the parts in, it could take up to a few days.
Old Jul 2, 2011, 11:37 AM
shadovarian's Avatar
Can anyone get me part numbers for these seals
aviseevuoptical
Feb 28, 2016 12:24 PM
stunna2o1
Jan 25, 2016 07:02 PM
TomekEVO
May 30, 2015 03:27 PM
yenny
21
Sep 12, 2012 11:28 AM
cornholio421
Oct 8, 2010 06:49 PM
Quick Reply: Leaking Transfercase/Transmission seal
