So this is Launch control/NLS?
Hi guys,
I had an idea this morning on how to incorporate a launch control and no-lift shift feature in the XEDE. With the new SMART system, one can pretty much design any table he wants with whatever X, Y and Z variable he can think off. So this time, we fed the factory clutch switch into an unused XEDE input. Then we set up a simple table with the Clutch switch as the Y axis, RPM as the X axis and MAFout as the Z variable. With the Launch Control/NLS limit set to 6600RPM, the table looks like this:
And with a simple Stg 1+ running 91oct, a blast quick blast up 1st through 4th gears looks like this:
http://www.vishnutuning.com/movie/boosto.mov
This was with me driving Dustin's car so I shifted gently with full clutch disengagements between gears. Even still, boost easily built 7psi right before the easy, no-chirp launch and never dropped below 9psi between shifts and hit hard and instantly once the clutch was let out again.
With our DSM drag racing buddy slamming through the gears earlier today, the boost would only fall to 17psi between shifts!
The secondary rev limit is triggered by the first clutch switch (the one that is tripped once the clutch is depressed an inch or so-- not the one that requires the clutch pedal to be pushed in all the way). So, in effect, you can activate the limiter by just barely touching the pedal. Also nice is that with the limiter set to 6500rpm, you can drive around all day like that and never notice it during normal driving (rev matching, double-clutching, heel/toe, etc,.) It's just there when you want to throw down
This user-settable feature is now available in all v3 XEDE maps, SMART or otherwise.
Next up: Anti Lag Vrooom... BANG BANG BANG BANG
Cheers,
Shiv
Cheers,
Shiv
So this is basically cutting fuel at the set RPM range then correct?
Also, i assume an XFlash is necessary to get past the factory limit to begin with?
[EDIT] OR, do you disconnect the clutch switch from the ECU and plug it into the XEDE instead? [/EDIT]
Shiv
Shiv
Originally Posted by Ninj0x
You completely disconnect the clutch switch from the ECU? Will that make it so you can start the car w/o the clutch in?
Shiv
On the 05s it triggers a secondary rev limiter. However on the 03, it does not seem to serve any purpose what so ever.
... So why is there a 1st clutch switch? What purpose does it serve?
But there could be somthing? Seems odd that that would be there to do nothing.
Shiv
Things like this sometimes make me want to switch to XEDE from AEM. Shiv they day you create a methanol injection kit that is controlled fully by XEDE - i will probably switch engine managment systems. I mean a kit that when methanol level is low or failing - the XEDE will automatically remove boost/fuel/timing and run soley off pump gas. Your recent progress is really impressive and really makes me think I am using the wrong EMS.
Krunal
btw.... do u speak hindi?
Krunal
Krunal
Krunal
The SMART XEDE can already control Methanol through a dedicated Methanol control table. It simply generates a user-definable 0-5v signal (as a function of MAF and RPM) and feeds it into the methanol pump controller. Then one can set-up another table (we call it "Lean Protect") that constantly monitors AFR under boost through the wideband input. If, above say 15psi, AFR ever goes leaner than say 13:1 (which is what happens when methanol runs out/jet clogse/etc,.), you can induce a fuel cut, boost cut, or a massive ignition retard (or any combination of the above). The SMART system really allows us to design any tuning template (up to 12 tables in all) to suit whatever need one may have. To be honest, stand alones are crude and inflexible by comparison. IMHO, of course.
It is possible to step the low current 0-5v methanol output to drive the pump directly instead of going through the pump controller box. But that would take a bit of time and involve the cost of an extra box. Someday, we might do it. But for now, it's just as easy to integrate XEDE control the Aklycontroller or Boost Cooler pump controller.
As for Hindi, I used to speak it when I first came to the US. But 25+ years of living in TX, NJ and CA have squeezed the last bit of fluency out of me
shiv
The shop manual says it is there to reduce emissions during shifts. Now it is your guess what that means in practice.
2 questions.....will the launch controls be saved on individual maps? Meaning you could have one map set with launch controls and the other without....or at least have it set to the point that it would feel like it wasn;t activated?
Also I just downloaded the newest version Xmap 3 off the vishnu site and no longer see the boost control features anymore...did i mess something up?
