Downpipe Bolts Coming Loose!???!
Old Jul 31, 2005 | 06:58 PM
Jeff_Jeske's Avatar
Originally Posted by Zeus
PS, with the Megan downpipe, you are supposed to take the OE donut gasket off! Otherwise the two flanges can not mate. I just used the cheap, crappy gasket supplied by Megan... and it still has not failed even with all the removal cycles.
The megan DP supplies another donut gasket......unless this big heavy lead like thing is not considered a donut.
Old Jul 31, 2005 | 07:22 PM
Zeus's Avatar
That's wierd... I need to get back with them and see if they took my suggestion to use an OEish donut down pipe flange. You used to only get a flat circular gasket made of the same material as the other ones provided.
Old Jul 31, 2005 | 07:27 PM
Spec'd's Avatar
Does the Megan Racing use a flange intended for a 3" O2 housing ?
Old Jul 31, 2005 | 08:58 PM
Jeff_Jeske's Avatar
The pipe that meets the O2 housing is actually bigger than 3"...the donut gasket that gets inserted is 3" inner diameter.....mine is just like the stock donut but a bigger. I dont believe the flanges are in contact with one another. I suppose the spring bolts would be the hot ticket in this config.
Old Jul 31, 2005 | 09:15 PM
BADEVO's Avatar
Originally Posted by inariv5573
Should've stuck with a downpipe that uses the spring bolts and donut gasket. That is what the car came with from the factory that is what you should've stuck with. It is funny when people deviate from what professional Mitsubishi engineers designed for the car and then wonder why there are problems.
Hmm... I guess EVERYTHING on the car should be left alone then since the PRO's at mitsu designed it, and lord knows they cant be wrong...
can they?
Hi guys. Just wondering if anyone is running the Denso/Supra fuel pump in their car. What adaptations do I need to perform to put it in, being it is not direct bolt on, thanks.
^^ Why bother mitsu pros would have thought of that.
ANYWAY
I have the Megan setup and have had 0 problems with it. Try a lock washer, if not try a lock nut on the end of the bolts itself.
Old Jul 31, 2005 | 09:53 PM
Jeff_Jeske's Avatar
Lets not go starting anything here......I was just providing a helpful heads up to all aftermarket downpipe owners. Who knows this could be from something I did wrong (not likely) but I wanted to hear everyones take on it.
I love my Megan TBE!
Tractionlimit
Aug 4, 2016 03:25 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
webguy330i
Sep 7, 2005 12:27 AM
EvilBlueEvo8
13
May 5, 2005 07:30 AM
MitsuJoe
Aug 1, 2004 01:59 PM
Quick Reply: Downpipe Bolts Coming Loose!???!
