Anyone using Fidenza Cam Gears, what cover are you using?
I recently bought an 03 Evo that had Fidenza cam gears on it with no cover. I want to put a cover on ASAP but i'm unsure of what will fit. I was told the stock cover wouldn't fit but a Zaklee clear cover would, then i was told by someone else that it was untested so it may or may not clear.
Anyone using Fidenza cam gears please post what cover you are using so i can finally buy one and know it will clear! Thank you!
yes the zaklee cam gear cover will fit your fidanze cam gears...someone already posted a thread about his zaklee cam gear cover and fidanza cam gears. definitely go with this cam gear cover because it is definitely an awesome piece. Rob at Zaklee did an awesome job fabricating it. type zaklee cam gear cover in the search thread and you will see numerous results of it. check it out. i have it myself!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
+1
Originally Posted by titaniumkingpin
or, you can just cut away at the stock cover.
i needed to take down the inside with a grinder. Took about 10 minutes and it does not rub anymore.
well when i bought the car it had no cover and no bolts... i am buying a clear one for $90 shipped and it's $7.42 for the 4 bolts from Mitsu. That setup will require no grinding or anything and it's not like i have a stock cover laying around.
ChicagoEvo9
Jun 25, 2014 05:47 AM
