Best Turbo Set Up for Pump Gas and Alky?
Old Aug 7, 2005, 04:34 PM
TwStDeVo's Avatar
I would like to upgrade my stock turbo for a turbo that would provide the best overall performance on the street/strip (mid to low 11s or faster). i will be using pump gas (91oct) and methanol all of the time. i want a set up that would be the best combination of racing from a standstill to racing from 40mph or so rolls. here are my choices so far:
1) Buschur 20g
2) gt35r
3) 2.3L gt35r
is the gt35r worth it for just pump and alky, say 26 or so psi? whats the most boost i could run on a 35r with or without the 2.3 on pump and alky?
one last thing, i live at an area that is almost 7000ft above sea level. ive heard both negative and positive things about the 35r at this level, not sure what the truth is. would the stock turbo spool slower here than at sea level? mine starts at 3100rpm and peaks at 3800rpm in 3rd gear, how does this compare to sea level?
I would appreciate any helpful information.
Old Aug 7, 2005, 04:42 PM
DCSilvrEvo's Avatar
I wanna know the same question...
Old Aug 7, 2005, 06:40 PM
TwStDeVo's Avatar
bump
Old Aug 7, 2005, 06:44 PM
PPI
PPI's Avatar
If "all" you are looking for is mid to low 11's, i would not go with a 35r. Many peeps have done 11's with the tme turbo, and i believe given more time the w/r turbo will show good results as well, and if you wanted even more top end you would prob. want a gt30 turbo....my favorites are the 3076 or the fp3065.
Old Aug 7, 2005, 07:54 PM
TwStDeVo's Avatar
well i said mid to low 11s because i figure 10s would not be possible on just pump and alky, if it is i definitely want to know how?
Old Aug 7, 2005, 08:36 PM
BadazzCR's Avatar
I would keep the stock turbo...
Old Aug 8, 2005, 12:10 AM
TwStDeVo's Avatar
what mods did you have on the car with 418whp 432tq? was this on race gas? also, how did your evo with 532whp feel? compared your sti?
Old Aug 8, 2005, 12:12 AM
memo3's Avatar
2.3L GT30
or
2.3L 20G or 2.0 20G
Old Aug 8, 2005, 06:47 AM
Ted B's Avatar
Originally Posted by TwStDeVo
...one last thing, i live at an area that is almost 7000ft above sea level. ive heard both negative and positive things about the 35r at this level, not sure what the truth is. would the stock turbo spool slower here than at sea level?
My money is on "YES", any given turbo should be expected to spool slower at altitude than at sea level.
Why?
The engine is less volumetrically efficient at that altitude, which means that it is moving less air per revolution. The characteristics of the turbo are static, so the effect is the same as reducing engine displacement while the turbo remains unchanged, which should be expected to delay spool time.
Old Aug 8, 2005, 01:56 PM
TwStDeVo's Avatar
bump
Old Aug 8, 2005, 02:01 PM
Evo Ate's Avatar
I am now installing the AMS 3071 and I will let you know if that will get it done...soon
Old Aug 8, 2005, 02:02 PM
htsai14752's Avatar
subscribe
Old Aug 8, 2005, 02:06 PM
wingless's Avatar
if you got the loot to do a 2.3L gt35r, I would consider a built 2.0 with a Evo400 turbo as well (TME+BB center section).
Depends if you want to rule street/autoX/smaller tracks.... Or... big track and drags?
Old Aug 8, 2005, 02:07 PM
3240's Avatar
I've dyno'd my car with a 2.3L stroker and HKS3240 turbo in Denver (5800 ft absl) and Philly. The turbo spools about 15% to 20% quicker in Philly vs. Denver. Keep this in mind if you plan on running at altitude. Also, low 11's at your altitude is going to be very difficult to achieve. I ran a best of about 11.4 @124 in Denver on C16. Another thing to consider is the fact that a turbo will not make as much boost up here as it does at sea level. I was only able to get 29 psi out of my 3240 in Denver but was able to hit 34 psi at sea level.
At your altitude I'd recommend the GT30. If you're going to occasionaly run C16 I might consider the GT35. A 2.3L stroker at altitude is a huge help but adds considerable cost to your project. Good luck with your decision.
I'll see if I still have my old dyno charts (altitude vs. sea level) and I'll post them for you
Old Aug 8, 2005, 05:21 PM
TwStDeVo's Avatar
wow, that is a considerable amount of difference in spool. i want to stay away from the gt30 turbos since they only spool a little faster than the 35r but do not make as much power. i was looking at the 3076 but decided against it due to the fact that it would take 30psi or so to get around 475whp.
i figure the next best choice over the 35r, like many tuners are saying, is the stock turbo or something similar, which is why i am interested in seing how that buschur 20g turns out. your set up seems very nice, what do you think it would have made (power wise) if you tuned it on 91oct and methanol? is a 2.3 better than a built 2.0 at this altitude? btw, cant wait to see how the new set up turns out!
Quick Reply: Best Turbo Set Up for Pump Gas and Alky?
