Upper IC Blowing off under boost
Old Aug 12, 2005 | 08:30 AM
sleet's Avatar
^ What size is needed tho?
Old Aug 12, 2005 | 08:48 AM
Jovani's Avatar
Originally Posted by Evoryder
it's happened to many ... happened to me...thought i blew my engine or turbo...
always make sure you have a flashlight, couple of tools and a old tshirt in your evo...
Yes it has, happends even to the best of us. Even the 22 second evos . Just get some t bolt clamps and all your problems are solved!
Old Aug 12, 2005 | 10:17 AM
RyanM's Avatar
The Manifold side is 2 3/4, the IC side is 2 3/8 for the upper
Old Aug 12, 2005 | 01:37 PM
sleet's Avatar
^ Thanks I'll head to NAPA and bring the clamp in and ask em' for a T-bolt in that size.
Old Aug 12, 2005 | 01:52 PM
matt55's Avatar
Iam running 3" on the t-body . Also the lower turbo to IC hose is 2-1/4" NAPA don't sell then that small got mine fron turbonetics(sp)
Old Aug 12, 2005 | 02:00 PM
sleet's Avatar
^ I'm talking about the connection on the upper IC pipe, the top peice on the pipe with the BOV connection. Is that size 2 3/8?
Old Aug 12, 2005 | 02:10 PM
matt55's Avatar
I think NAPA uses the 2-3/8" as the smallest the clamp will go(bottom out) . I have the stock upper IC flex hose in my hand now and it a hair shy of of 2-3/4 '' so IIRC i got some 2-1/2" clamps . might as well get all of them at once , and dont forget to pressure test your system for leaks !
Old Aug 12, 2005 | 02:38 PM
sleet's Avatar
^ So the 2 3/8 would work for the upper pipe? All my other connections are fine except that one keeps poping off and nailing my hood lol
Old Aug 12, 2005 | 02:39 PM
hueman's Avatar
how do you do the hairspray stuff? inside the pipe?
Old Aug 12, 2005 | 02:51 PM
RyanM's Avatar
You can do that, but I think if your running 21psi your going to have the same problem (eventually). Definitely go with Tbolts, it sounds like the best long term/worry free approach. I'm **** and bought new hoses as well but thats probably not necessary.
