Best bolt on gt30 kit ATP vs Vishnu vs Buschur
#136
gsujeff,
The car has our 3071 kit, AEM EMS. Car has 280 cams, mildly ported head, Stg 3 shortblock, 2 liter, Greddy smallish FMIC, 3" exhaust, straight 93 octane, 3" inlet pipe and open element filter. Stock'ish upper i/c pipe, 2.5" lower i/c pipe, manual boost controller, intank pump, 680 cc injectors.
David Buschur
www.buschurracing.com
David Buschur
#137
Originally Posted by davidbuschur
Derek, the GT35 numbers are on straight race gas, no alky.
supernaut, the GT3076 doesn't spool that much faster than the GT35R that is why I say if you are torn between the two you may as well go with the GT35R. The 3071 will probably be fine with the 680 injectors we sell. I'll know this afternoon.
luxurybroker, spool on the new GT35R kit is 20 psi by 5,000 rpm. Lazy for a street turbo in my opinion. I haven't dyno'd a GT35r on straight pump gas.
jj008, to me a 700 rpm difference in full boost isn't worth the difference between being able to make 500 hp and 600+ hp. I'll take the 700 rpm's and the extra 100+ hp anyday.
statix, all turbo kits are held on by bolts or studs. The new kit uses studs and steel lock nuts.
David Buschur
David Buschur
and in reference to this sentence above... you would... but i wouldn't :\
Originally Posted by Supernaut
How in the hack do you get 98 octane?
I figure a 3071-37-76R would be good for atleast 420WHP on a dyno jet on pump gas?
#139
Here is the dyno chart from our dyno. 22 psi, GT3071 kit. Staight 93 octane, no alky, no race gas, no cheating. Car has a small Greddy FMIC on it, mildly ported head, 3" exhaust with one resonator and large muffler.
Is there any new developments in this kit?
I noticed in this dyno chart that the torque number seems really really low for such a large turbo, even on pump gas. Is there a reason for that?
#141
There are no "new" developments in the kit. We have changed turbine housings to one that matches our manifold design. This new turbine housing has an integrated wastegate port. We use a 44 mm Tial wastegate on all the systems now. This new turbine housing is very lightweight and stainless steel. Every turbo kit also has the manifold ceramic coated too.
The GT3071 on our dyno with 93 octane/alky made 350 whp, that is a good number on our dyno for "small" turbo. That is the car I was speaking of earlier in this thread. Our GT35R kit has made (as of Friday last week) 551 whp on race gas on our dyno.
The black car is still getting a cage put in it, when it comes back I hope to be able to post some new results.
As far as reading all the "bull****" tynidex, I don't know what to tell you. What I type is what I think.
David Buschur
David Buschur
#144
I am going to have to agree with David, we tuned my personal car this weekend with a 30r .63 and made 360whp on 91, 453 on race gas. Pump was 21 psi, race gas was 26. The turbo was out of breath, we upped the boost 1psi to see what we would get and gained .5whp so she was done. The car has a pretty heafty powerband, but still doesnt fully come on till about 4k. I think a .63 35r would have come on only a fraction later and made much better numbers. I am pretty happy with the numbers the car made however with that turbo.
#145
I ran a 11.54 @ 121.6 this weekend on pump gas, 26psi and alky with BR's OLD STYLE GT30R (aka BR500bb). The tubo makes some pretty good low end power though, I was hitting pretty consistant 95 mph 1/8 times. Interesting thing is upping the boost to 28psi, adding some race gas, and leaning her out a bit (timing looked good and egr's were 850c) and it diden't go any faster. This is the OLD kit from BR with the integrated wg on it. I am pretty sure if I hammered the shifts, leaned it out a few .10 and pulled the usual low 1.60's it would run a solid 11.40 and possibly a 11.30. I think that is about all I am going to get out of this turbo.
#146
Nice times 4ring. The car could be tuned a lot more aggressively on race gas and run even faster. Just making the point, the times you are running now are great!
David Buschur
David Buschur
Jrod@Buschur
Feb 6, 2004 01:41 AM
