AMS 3071 kit finally tuned ... link to info
For those interested, I've posted dyno charts showing the effects of cam timing testing, afr adjustment, and boost adjustments in my Evo work-in-progress thread. Lots of info, go take a look.
Final numbers came in at 376whp/319tq on a 93 Octane tune.
l8r)
l8r)
Originally Posted by 1.8t
A built motor and "only " 380whp. That motor is going to last a LONGGGGGGG time . Congrats on the numbers.
Mod list:
- Vishnu Signature Series exhaust (3")
- Vishnu HF cat (cat and test pipe converted to full v-band flanges)
- AMS GT3071 turbo kit
- AMS built 2.0 liter (ross pistons, crower rods, built valvetrain)
- AMS FMIC
- K&N intake
- HKS 280 cams
- Vishnu Camgears set to -2 intake / 0 exhaust
- Greddy Type-S BOV
- Vishnu XEDE piggyback
- XEDEflashed ECU
- Innovate LM-1
- Rotorpro rotors/Hawk HPS pads/SS brake lines
- Mitsubishi brake ducts
- Custom brake ducting
- SS clutch line ... STOCK CLUTCH (yes, it's the one the car came with, 32k on the clock)
Also, the goal was not to build a dyno queen or a drag racer ... this setup was built for road racing/street driving and as such it needs to have a conservative tune ... though 376 on pump with a cat ain't too shabby, IMO.
Suspension tuning is next.
l8r)
Originally Posted by NOLIMITMOTORS
i made 379 whp and 372 tq on stock turbo with 280's, reflash on 93 octane
ok 280's with meth are in my 2005 evo. after reflash i made 379 whp and 372 wtq. car feels pretty good but I def need alot more power. I think i need 450-475 whp. GT30R next!!!
Originally Posted by 3deep
I like your cam timing test.I wonder if the results are apllicable for other cam profiles like 264 or 272's.
Originally Posted by lexat20
Luda, Congrats on those numbers, you owe me a ride. The 272's are working great. I cant believe the difference they made...
The tune was done by Martin at AMS ... again many thanks go out to their patience in getting this all to work. Boost is currently set to ~22psi, tapering to 21psi by redline. In pouring over my dyno runs, I have some thoughts on how I might retune, but for now I'm very happy with the setup. I am having some issues with minor compressor surge, which I'm very sure is related to my Greddy Type-S. I will be ugrading to a Greddy Type-RS (40mm instead of 37mm on the S) shortly to see if that helps.
l8r)
All of my dyno runs were on a dynojet of one type of another. However the baseline was performed in Denver, so it is probably a good 15-20whp lower than it would have been in Chicago.
At some point in time, I might go back to the same dyno that my most recent runs were performed at (Porsche Exchange with Vishnu stage 1+) to get a better comparison.
l8r)
l8r)
l8r)
l8r)
Seriously, it's great to see your car is finally sorted out.
Quick question: why does it look like you power stalls out from 5000 to 5500 rpm?
The power valley at 5K is only evident in the 3rd gear pulls, 4th gear pull is much smoother. I asked Martin about that and he says it's due to the car putting down more torque in 3rd gear and loading up the dyno more as it spools up. I can post a 3rd gear vs 4th gear chart if you want to see the difference.
l8r)
