Gauge install!! Please help!
Ok I just recently purchased 3 autometer gauges for my evo. Boost, water temp and oil pressure, installed the boost gauge and it works fine. I am trying to install the water temp gauge but I cant figure out how to get both the factory temp gauge and the autometer to both work, I know some of you guys have done it... HOW??????? Do I nstall the autometer temp sender or leave the stock one? When i tried to wire the new autometer to the factory sender it said my water temp was 230 degree's and my factory gauge did nothing. Please help.
yeah i also need some help on this...i cant figure out to install defi water temp gauge..
i dont want to cut the radiator hose and put t connector to put the sensor....
how can i tee in to factory sender??
if i cut the radiator hose, i should i do it? wont fluid still be there? isn't it pressurized?
how to get rid of air bubble?
and if i can tee off the stock sender unit, i dont want to cut up the hose..
Attaching temperature sending units to tees isn't such a great idea if you're looking for an accurate reading. A tee works fine for pressure senders but for temperature the sensor needs to be in the flow of fluid otherwise you're waiting for the heat to migrate to the relatively stagnant fluid in the tee.
The primary reason I installed an 1/8" NPT bung on my oil pan was so I could get an accurate oil temperature reading.
