Let's talk HKS EVC V
I currently run a GReddy Profec B Spec II. I dislike it. Yes, I know how to set it properly. No, I don't want to debate Profec vs. EVC, take it elsewhere.
I have heard great things about the HKS EVC V. It is a lot of money but at this point I am willing to spend a bit more for a good component. There are two versions, a PSI and a KPa version. Normally I would perfer the KPA version, but for whatever reason the PSI version is a bit more money. I need to know why.
Can someone please list the differences between the PSI and KPa versions? I can't imagine one would be MORE money just because it reads differently.
Thanks in advance.
Thanks in advance.
I had the PSI version it was great. The only difference between the two from what I understand is reading betweem KPA and PSI. I did also hear that the KPA might be more accurate reading but I am not sure of that.
Originally Posted by EvoJimbo
I believe the PSI version has the offset function. Other than that they both the same.
I believe the offset function is available on the KPA version.
http://hksusa.com/products/more.asp?id=1651
the psi version is actually less expensive - and it is also now discontinued. The only version available now is the Kpa
the Kpa version has the offset function and peak hold...other than that they are the same units
We do have one PSI version left in stock however
bishiboy
23
May 14, 2004 12:14 PM
