atpGT3071R turbo kit
im thinking about getting a GT3071R turbo kit--
if you already have one how much hp is it pushing and did u have to change ur stock clutch or can the stock clutch hold the power ---- and do u have to buy anything else or is everything needed is in the kit
Originally Posted by DCSilvrEvo
Im thinking of getting one and boring the hot side out a little so it will spool faster because as they are sold they are kinda laggy.
I feel as long as you stay with a 3071, you should'nt have lag issues, that turbo is quiet small and spools pretty quick, even with the ATP kit.
Originally Posted by statix
Problem is, by porting out the hotside you'll only be adding to the lag, if anything you could get a bigger a/r housing to make a little more top end, but again it will only add to the lag.
Thugline
Jul 25, 2006 07:52 AM
