SS manifolds Cracking.....What causes them to break?
Besides the obvious in terms of POOR welds and just general poor manufacturing, what causes an SS Manifold to crack or even just separate?
If you look at DSM's, they just hung the Turbo off the manfold and that was that. The DSM Downpipe DID however have a Flex section.
Enter the Evo VIII, the Stock turbo is hung off the very same (similar in strength atleast) Cast manifold YET has a support bracket as well. The stock downpipe does NOT use a Flex section.
If you look at the AMS Units and the Vishnu units (some of the Vishnu Turbo Kits use the AMS Manifold) they use a support backet that either holds the weight of the turbo OR prevents some shaking. My guess it keeps the unit from shaking as the Mitsu engineers put one one as their was no flex section.
I have yet to hear of an AMS manifold crack.
Look at the RnR setup, the don't use a supporyt bracket. They also use a Downpipe that ADDS a flex section. Again I have yet to hear of a RnR manifold crack except for STVBREAL which had a leak, and his did not crack so much as it came with a faulty weld which is simply a manufacturors error.
There are two Greddy turbo kits on this site with cracked manifolds. I have no Idea on the Turbo Trixx Manifold but I haven't heard anything bad from them.
I Guess my point is that the VIBRATION kills a manifold, not so much the weight of the turbo, any other inputs?
Thanks.
P.S. does the addition of a flex section hinder exhaust flow? Why do you think mistu ommited it?
Thanks.
If you wrap the header it should be less prone to cracking. One of the worst things that can happen is to have your shiney new header nearly red hot get doused with fresh rain...
Originally Posted by EvlEvo8
Besides the obvious in terms of POOR welds and just general poor manufacturing, what causes an SS Manifold to crack or even just separate?? ...
Originally Posted by RyanM
321 would be great, but who makes a header with it? I haven't seen much 321SS around.
PeakBoost manifold 321ss 8 gauge stainless steel, lifetime warranty.
scheduled for release 9/15/05.
let me know if you have any questions
Cast manifolds are a lot stronger than most SS tubular stuff especially the thin wall and improperly welded ones. Properly bracing tubular SS manifolds is recommended. There is a trememndous amount of weight and leverage acting on some setups, that, and the high heat in use softens it up. Take some cues from the F1 turbos... https://www.evolutionm.net/forums/sh...63&postcount=5
Cast manifolds are much thicker and can take the heat loading better.
SS ones are usually thinner and dissipate the heat more quickly. This equates to more "up and down" temp cycles, which fatigues metal a lot.
The first post mentioned that we don't have a flex section? I haven't looked, but there has to be some sort of movable section, or the engine rocking would snap some exhaust welds pretty quick. I'll check the service manual, I'm pretty sure we at least have a knuckle or expansion pipe down there.
AC
AC
Originally Posted by PeakBoost ken
we do
Originally Posted by Derek888
can you use the stock radiator, seems like it will touch the manifold? sorry for the OT. btw check your pm.
we are trying to make sure that we cover every base with the PeakBoost GT kit, leaving no stone unturned
Originally Posted by LordEvoIX
Wow! That SS321 peakboost manifold is beautiful! What's the gains like?
we should have some #'s for you guys in the next coming weeks.
we got the HYDRA ems for our R&D car on friday, and ive been doing a bit of street tuning. surprised the hell out of me, how easy the HYDRA was to bring up an initial startup, as opposed to the other systems ive used.
the HYDRA fired and ran like a factory car, out of the box...
Originally Posted by Shearer
Peakboost, those fittings are 321?
we used to use a 304ss forged fitting, but never on the EVO manis.
All PeakBoost manifolds are now 321ss forged.
heres some pics of the finished PeakBoost charge pipes:
let us know what you guys think.
ken
p.s. happy day off to everyone
