defi d-gauge reading correctly
Old Sep 4, 2005, 02:51 PM
hawaiievo's Avatar
when the car is off my boost gauge is reading 1" vac. i have my mbc set at 20psi. does this mean that i am only running 19psi instead of 20psi?
Old Sep 4, 2005, 07:52 PM
hawaiievo's Avatar
bump
anyone??
Old Sep 5, 2005, 12:15 PM
hawaiievo's Avatar
nobody knows???
Old Sep 5, 2005, 03:02 PM
dan628's Avatar
this is just a guess... but if the car is off there is no reading on the gauge, the needle just drops back kinda like the rest of your gauges.... I just ordered the same gauge so when I install it I'll see how mine reads. How does it read when you have the car on at idle?
Old Sep 5, 2005, 03:06 PM
hawaiievo's Avatar
at idle its about 20-21" hg
Old Sep 5, 2005, 03:37 PM
[Cyanide]'s Avatar
When your car is off it should read ZERO.
No vacuum or boost at all.
At idle it should be anywhere between 15-20"hg.
If your needle isn't zero'ed when your car is off or even before you put the boost gauge on the car, send it back for a properly calibrated gauge.
In fact, take a picture of your boost gauge when your car is off & post it here.
I had a bad D-Series boost gauge sent to me once, it was off by 5psi
Old Sep 5, 2005, 04:32 PM
hawaiievo's Avatar
so what your sayin is that im running 19psi instead of 20
Old Sep 5, 2005, 04:51 PM
bigjhoney's Avatar
I know some autometers sit a little off, but it doesnt affect the calibration.
Old Sep 5, 2005, 04:55 PM
hawaiievo's Avatar
wait its showing 20psi so i'm only running 19, should i just bump it up to 21 if i want to run 20
Old Sep 8, 2005, 10:41 AM
dan628's Avatar
Hey I installed my DEFI gauge last night, it reads 0 when its off, and about 20 in-hg vac at idle... Under full acceleration it spikes up to like 22 PSI and drops to like 17-18...
Old Sep 8, 2005, 01:21 PM
Silver Sponsor
RallySport Direct's Avatar
Defi gauges are VERY accurate. One of the best gauges on the market. IMO
Also people reading the specs of 20hg-15hg remember cams will reduce the amount vaccum you car has so. people with cams could see 15-10hg. If it goes any lower that normally means that your motor is not doing very well.
dan628 - what you are experiencing is very normal. The reason the gauge is reading the boost is falling off is because it is.
Ben
Old Sep 8, 2005, 01:30 PM
fsugatorbait's Avatar
Ben
Ben,
Ive noticed that with the cams I used to idle around 15hg, recently thats moved up to around 17hg. Would you mind giving a brief explanation of what could cause this?
Old Sep 8, 2005, 01:38 PM
Silver Sponsor
That is very rare for it to do.
Most aftermarket cams have a greater overlap in duration(which gives the cool lug lug at idle)
This causes the vaccum reading to go down.
I have no clue why your went up. What cams did you use? Anything else changed at the time? Cam Gears?
Ben
Old Sep 8, 2005, 01:46 PM
Ben
GSC 272/264. Ive only had them for about 3 weeks now or 1k miles. Head studs were also installed at the same time. I had a very pronounced lope after install which has decreased slightly as well.
Old Sep 8, 2005, 01:53 PM
EVO8LTW's Avatar
If the gauge doesn't sit at zero when the car is off it's either defective or was damaged in shipping. Do a search on the Honda-Tech forum and you'll find a lot of information about this.
Quick Reply: defi d-gauge reading correctly
