Boost problem Please Help!!!!
Like I said before I checked and found one leak in the turbo outlet pipe I fixed and still the same amount of boost 12 psi could it be the Forge DIV BOV or wtf this problem started when I instal the Fu**** Helix IC Kit, someone please help
If u have a boost controller it might be on the wrong way if u took it off when installing the other things, or its not adjusted right, i know that when i put the boost ocntroller in the right way and had the screw turned one way it would only hold 12 psi or so and then adjusting it from there to 21.
SSickLS1
Sep 1, 2011 10:43 PM
wickedwhiteIX
10
Mar 30, 2009 06:19 PM
