Best Spark Plugs - Big Turbo, Big Boost?
I would really like to get some expert opinions on the best performing spark plugs for my car. I'm running a GT35R with the intent on running Alky Injection and 25-26 lbs. of boost for daily driving and 28-30 lbs. (on race gas) at the track.
I've done several searches and have read many mixed answers. BPR7ES, BR8ES etc., etc. Iridium or copper...the suggestions are all over the place. Gaps from 28 down to 22.
Soooo, anybody running a big turbo with elevated boost, please post what has worked best for you.
Thanks in advance for your suggestions!
It is difficult to say which is better. If I were you I would try BR8EIX or BR8ES.
Standard Gap is .7mm, try it and if you have missfire reduce to .6mm or less.
Heard good things about BR8EIX in the lancerregister forum, one guy there is running with 1.6bar and said that had good results with BR8EIX.
I've had it for a couple of months or so. I didn't like the numbers I was getting with the 3076. The 35r is worth more than 100whp over the 3076, with no (or little) difference in spool. Just trying to work out the little bugs right now.
So...would everyone (anyone) agree that the best way to go is with BPR8ES and change them with every oil change?
Yes!
Yes!
Originally Posted by SwiftEVO
Did you get the rnr kit? Thats the one I got(3076). Im getting tuned by mark (TT) in Oct in tx.
--Josh
--Josh
I've run "high" boost with a gt35r, a lot of meth. injection and had NO problems with blowing out spark on my 2G. Using BPR7ES with a .026" gap.
Nismo2evoawd
Jan 30, 2010 05:22 PM
