Who Is Making Over 450 Whp On A Cusco Twin Disc With No Problems???
I'm contemplating the new heavy duty exedy twin disc and the cusco twin disc and also going to be upgrading the turbo over fall/winter. I'll be shootin for somewhere betweem 450-500 whp on pump with methanol (most likely a GT35R)
I'm really considering this cusco twin but Its so rare I see people using it. One person told me its good for 450-500 whp which i dont like to hear because I dont want to be maxxing it out. another said 550whp. I know its very similar to the exedy twin disc but the discs are a different material and the pressure plate is a little different other then being blue instead of purple. I might even order the cusco discs with the new heavy duty exedy pressure plate but i'm not 100% sure yet. Is there anyone out there making 450whp+ with the cusco twin with no issues??? Or any other imput is appreciated.
Exedy
In case you did not know... The cusco is the same clutch just painted blue..
Chris
Ok... I'll settle this right now.
The Cusco Twin is IDENTICAL to the 'MM022SD' which is the Exedy Twin Metallic.
The ONLY difference is the covers are painted different.
Cusco may say they are a different disc - but they aren't, it's only marketing.
However, the NEW MM022HD is different that the two I mentioned... but the ONLY difference is the clamp load of the diaphram... in other words, same discs but it hold 15% additional power.
Hope that clears things up... and if you need the Heavy Duty Twin... I have them in stock.
Cusco is NOT carbon disks - they are carbon/metal blend, whereas Exedy is metal/ceramic blend
"TWIN PLATE CLUTCH SYSTEM- Easy to slip in, diaphragm designed for smooth and light use. A light clutch that enables good clutch maneuvers.
Carbon rich facing used on the disc with ventilated type center plate.
The self leveling system balances equal wear on both the flywheel side and transmission side of the disc to promote longer clutch life.
CUSCO "Pull Type" Clutch Systems do not require the "Pull to Push" conversion adapter kit unlike the ones of other companies. It will provide you an advantage of proper and easier installation, also with higher reliability and durability through out the whole life of the clutch system. "Bolt-on Design" also supports these advantages and benefits you gain from CUSCO Clutch Systems.
*Pull type and push type are used depending on the cars."
Cusco marketing at its best. Adam did you know matt used to work for exedy? Cusco clutches are blue MM022SD clutches.
Chris
Chris - yes I have known Matt for nearly 5 years now
and no, they are not the same - the above is direct qupte from Cusco...I am sure they have no reason to lie, nor do I have a reason to make it up
matt, even you said you can call exedy and order the cusco style discs which are different then the standard twin disc clutch, didnt you?
Trust me - I have nothing to gain out of this. They are the same.
