What turbo is that ? GT3071 ??? Please help...
Hello guys,
sorry but I need your help.
I recently bought a turbo in Usa for my Evo6 TME,
and I personally trust the people ( no names for now ) that sold it to me...
but it seems to me to be externally quite different to the one I ordered.
I ordered a GT3071R.63
- T31 ar 0.63 exhaust housing - wheel 60mm w/84 trim
- compressor: 4" inlet - 71mm wheel w/56 trim - ar 0.50
and this is the one I received:
I immediately asked informations to the seller, cause was evidently a 0.70 a/r compressor housing, and that was his reply:
" This is a GT3071R, not the GT3076R. The true ones comes with the .70A/R compressor housing, not the .50A/R. The .70A/R T04S cover is usually more expensive and much nicer then the ugly .50A/R compressor cover. Its a 71mm 56 trim wheel up front... "
What do you think ?
Thank you !
What do you think ?
Thank you !
It is odd that it comes w/ a .70 A/R compressor cover. According to Garrett, a true Garrett has a .50 or a .60. The only way to find out what CHRA is to pull off the covers and measure the wheels.
Originally Posted by NOLIMITMOTORS
very odd to see a GT3071 with a To4S cover (meaning 4" inlet, 2.5" outlet) usually its a tO4E cover which has a 3" inlet and 2" outlet.
This could be a special order turbo from garret you bought.
Look at the center section of the turbo. There should be a little tap there with serial and part number. you can match that up with the part # from garrett to find out what turbo you have.
Originally Posted by WrX Kila
That's is not a 4inch inlet. I have a 3076 with a T04s cover and its much bigger than that. You do have a .63 backhousing though.
Hi WrX Kila,
believe me.... it's a 4inch inlet... it is sitting now in front of me !
Bye
Originally Posted by EFIxMR
you can get a 3071R with an S housing. check this one out that I have.
thank you EFIxMR !
PS: how does it go ? Have you already used it ?
Bye
XTR Performance
16
Jun 5, 2013 09:16 AM
hydra
30
Nov 23, 2011 03:02 PM
smg944
Aug 16, 2010 08:20 AM
Ted B
May 19, 2010 07:01 AM
