when will injectors be needed?
Old Sep 18, 2005 | 02:17 PM
rghli's Avatar
i am going to install the 272/272 cams. all i have now is turbo back and EBC. will i need to upgrade the injectors?
Old Sep 18, 2005 | 02:22 PM
ev08buoy's Avatar
injectors will be required when you upgrade your turbo.. till then I thought the stock injectors were pretty big.
Old Sep 18, 2005 | 02:27 PM
evo8act's Avatar
you dont need to change injectors until you upgrade your turbo. Good luck
Old Sep 18, 2005 | 02:37 PM
EvoTech's Avatar
Not true. You need to upgrade your injectors when the duty cycle is sbove 95%. With a stock turbo, cams and basic bolt on mods will get you to the point that you need injectors if you are running high boost.
Old Sep 18, 2005 | 04:50 PM
propellerhead's Avatar
I agree with EvoTech. A Buschur Stage 3 set up will push the stock injectors over 95% duty cycle. You might be able to upgrade the fuel pump to get by but you'll need a reflash and if you're gonna get a reflash you might as well reflash for a new set of injectors. That's my opinion anyway. FWIW, the Buschur Stage 4 with 680s will run IDCs in the 70-75% range.
Old Sep 18, 2005 | 04:52 PM
Curt@MrLed's Avatar
Former Vendor
a set of 680 or 720's will never hurt to have...
Old Sep 18, 2005 | 05:18 PM
KTT's Avatar
KTT
How do you know when a 95% duty cycle has been surpassed... I ask cause I am getting a custom Dynoflashnext month and I will get injectors before if I need to, does it seem necessary with the mods listed in my signature?
Old Sep 18, 2005 | 06:41 PM
Ted B's Avatar
In one word, NO.
Old Sep 18, 2005 | 09:19 PM
rghli's Avatar
thanks for the opinions. so far i am setting up my car for autox events. still looking for a way that i can afford the setup and finish all the necessary parts first.
Old Sep 18, 2005 | 10:22 PM
USAF_STi's Avatar
sorry to hijack the thread but since i am a newbie what size are the stock injectors?
Old Sep 18, 2005 | 10:43 PM
ctx2000's Avatar
stock injector is 550cc
Old Sep 19, 2005 | 03:26 AM
EVO8LTW's Avatar
And my BR Stg 4 with WR sees duty cycles in the 85-86% range with 660s on 93. Add race gas and more boost and the injectors are definitely required.
Old Sep 22, 2005 | 02:56 PM
rghli's Avatar
thanks guys. what about fuel pump? i see most of you who have cams upgraded have fuel pump upgraded too
Old Sep 22, 2005 | 04:24 PM
EVO8LTW's Avatar
Definitely do a fuel pump with cams.
Old Sep 22, 2005 | 04:35 PM
Boltz.'s Avatar
FCOTM Winner
Throw in some alchohol/meth and you can get a lot more power while keeping the stock injectors.....
Quick Reply: when will injectors be needed?
