AEM EMS and the Stock Turbo
The thought of using an AEM EMS has eneter my mind and I was wondering if there are benefits to using it on a stock trubo vs a flash? What exactly does it do better in terms of drivability and spoolup? Gas Milage? Can you set a launch control to that it ONLY works at launch and not in every gear?
I am also wondering if you need to use larger injectors on an AEM EMS vs. the stock ECU as it is less overlap when it opens and closes the suckers. ALSO I hear that if you want to run 30PSI, the EMS has an issue with its spark at that level and then you need a coil on plug ignition.
I am looking to max out my stock turbo with some ALKY, but I want to make sure an EMS is worth the cost of entry.
Why don't you check out the AEM EMS Dyno day article here: https://www.evolutionm.net/features/...vomfeatures/38
Oh boy thanks guys. I just heard osm issues with needing to run LARGER injectors cuz they open and close faster so you need larger injectors and also ignition is compromised. People can hit 30PSI on the stock ignition and ecu from what I have been seeing.
AEM EMS is IMO the best mod you can do....with the proper tuning your car will run smoother, get better gas milage, idle perfect with aftermarket cams, and ofcouse the car will be faster.....
