Installation of Forge Wastegate Actuator
I installed the Forge Wastegate Actuator today and I cannot go over 14psi. It also hits 14 psi at around 5-6k. I have delayed boost and low preasure. I installed the unit in the same location as the stock actuator. Is there anything I need to adjust on the Forge unit? When attaching the actuator's lever to the wastegate, is it supose to be in the closed position? With the stock unit I was peaking at 22psi and going around 18-16psi at redline. I am using the Halman RX Pro boost controller. Before anyone asks the vacuum hose to the actuator is connected.
Here are some pictures of the installed unit.
In this picture the actuator's lever has the wastegate shut.
This is just another pic of the whole unit.
If anyone has any suggestions please help. If you need a better picture or something I can go out and take one.
Originally Posted by atlvalet
There are different springs you can put in the actuator. What strength spring do you have in there right now?
You will likely need to play with the adjustment of the unit.
The turnbuckle at the and of the rod needs to be turned in towards the body of the actuator to add pre-load to the spring in order the turn up the boost.
If the turnbuckle is turned out, away from the body of the actuator, too far, you will not be able to increase the boost!
Boost still dropping at redline after Forge Wastegate Actuator Install
This post is not to slam the product. I was having these problems before the actuator. I feel the engine is building boost quicker, so thats a positive. I can't hold the boost all the way to the redline. My boost peaks at 21 PSI by 4300 RPM, but eventually drops all the way to 14 PSI at the redline. I have done a preasure test and have found no leaks. Is there something I am missing with my setup? Here is a log of my 4th gear pull.
Code:
RPM PSI MAF TPS Load Knock AFR Ing Timing Mod Maf 2262 1.8 321 100 10 0 11.8 13.5 ECU. 280 2284 2.3 325 100 10 0 11.6 13.8 ECU. 273 2302 2.7 332 100 10 0 11.6 14.2 ECU. 369 2344 3 346 100 10 0 11.7 14.7 ECU. 299 2375 3.4 348 100 10 0 11.8 15.1 ECU. 374 2422 3.5 362 100 10 0 11.8 15.4 ECU. 356 2469 3.7 376 100 10 0 11.8 15.7 ECU. 337 2495 3.9 376 100 10 0 11.9 16.4 ECU. 388 2538 4 389 100 10 0 11.9 16.9 ECU. 427 2575 4.2 401 100 10 0 11.9 17.7 ECU. 403 2624 4.4 437 100 10 0 11.9 18.3 ECU. 346 2645 4.7 431 100 10 0 11.8 19.4 ECU. 478 2712 4.9 455 100 10 0 11.7 19.6 ECU. 523 2730 5.2 466 100 10 0 12 20.5 ECU. 497 2780 5.5 514 100 10 0 11.9 21.5 14.5 509 2832 6 519 100 10 0 11.8 22.7 14.4 457 2873 6.4 554 100 10 0 11.7 23.6 14.3 456 2955 6.9 576 100 10 0 11.8 24.4 14.2 708 3019 7.2 631 100 10 0 11.9 25.7 14.1 735 3063 7.7 662 100 10 0 12 27.5 14 769 3095 8.4 664 100 10 0 12 28.6 13.9 580 3162 9.1 694 100 10 0 12.1 30.6 13.8 584 3229 9.6 777 100 10 0 12.2 33.6 13.7 889 3290 10.4 811 100 10 0 12 35.2 13.5 819 3367 11.2 871 100 20 0 11.9 37.5 10.6 976 3436 12.1 917 100 20 0 11.9 40.2 10.4 936 3505 13.1 990 100 30 0 12 44.1 9.1 1141 3584 13.9 1061 100 30 0 12 52.2 9 1012 3663 14.9 1131 100 40 0 10.4 55.3 7.7 1256 3741 16 1170 100 40 0 10.6 57.7 7.7 1126 3813 17 1282 100 50 0 10.7 60.2 6.4 1282 3907 18 1326 100 50 0 10.5 65.8 7 1152 3982 19 1449 100 60 0 10.5 67.9 6.9 1533 4074 19.8 1404 100 60 0 10.5 69.8 7.1 1366 4145 20.5 1557 100 70 0 10.4 72.7 6.9 1623 4235 21 1587 100 70 0 10.3 70.3 6.9 1736 4345 21.2 1519 100 80 0 10.6 70.6 10.1 1497 4432 21.3 1529 100 80 0 10.7 70.8 10.5 1633 4516 21.3 1587 100 80 0 10.8 72.1 10.7 1644 4604 21.2 1612 100 80 0 10.6 74.4 11 1644 4694 21 1607 100 80 0 10.5 74.2 11.4 1552 4748 20.8 1639 100 90 0 10.6 74 12 1712 4852 20.7 1661 100 90 0 10.6 75.9 12.4 1655 4930 20.3 1666 100 90 0 10.5 75.5 12.6 1623 5035 20.2 1677 100 90 0 10.5 79.6 13 1677 5128 20 1718 100 90 0 10.5 77.7 13.2 1655 5184 19.6 1712 100 100 0 10.6 79.3 14.1 1748 5265 19.5 1748 100 100 0 10.5 79.3 14.4 1773 5341 19.3 1773 100 100 0 10.6 76.6 14.7 1712 5420 19.1 1818 100 100 0 10.8 78.8 15.1 1824 5500 19 1831 100 100 0 10.8 78.6 15.5 1677 5574 18.8 1805 100 100 0 10.8 78.4 15.7 1773 5649 18.5 1831 100 100 0 10.8 79.3 16 1798 5727 18.3 1838 96 100 0 10.8 79.6 16.4 1689 5787 18 1858 81 100 0 10.7 80.1 16.6 1773 5858 17.8 1865 70 100 0 10.8 79.3 16.8 1748 5931 17.6 1901 88 100 0 10.9 80.4 17.2 1785 6016 17.6 1872 65 100 0 10.8 79.8 17.5 1785 6060 17.5 1893 68 100 0 10.9 80.1 17.9 1798 6127 17.3 1937 94 100 0 10.9 81.5 18.4 1724 6207 17.1 1930 100 100 0 10.9 80.8 18.5 1785 6277 17.1 1945 100 100 0 10.8 81.7 19.1 1851 6337 17 1992 100 100 0 10.8 81.9 19.3 1908 6397 16.8 1953 100 100 0 10.9 81.6 19.5 1748 6447 16.6 1945 100 100 0 10.9 81.7 19.8 1851 6510 16.5 1953 100 100 0 10.9 82.4 20 1893 6574 16.1 1960 100 100 0 10.9 81.7 20 1824 6626 16 1976 100 100 0 10.9 82 20.1 1838 6680 15.8 1953 100 100 0 10.9 81.6 20.1 1865 6734 15.6 1953 100 100 0 10.9 81.8 20.1 1811 6761 15.4 1968 100 100 0 10.9 81.2 20.2 1838 6844 15.3 1960 100 100 0 10.9 82 20.2 1893 6901 15.1 1960 100 100 0 10.9 81.7 20.3 1893 6944 14.9 2000 100 100 0 10.9 82.9 20.3 1879 6988 14.9 1976 100 100 0 10.8 82.8 20.3 1798 7032 14.8 2000 100 100 0 10.7 84 20.4 1811 7077 14.8 1992 100 100 0 10.8 84 20.4 1785 7122 14.8 2016 100 100 0 10.7 83.9 20.5 1851 7168 14.6 1992 100 100 0 10.7 85.1 20.5 1851 7230 14.6 2016 100 100 0 10.7 85.2 20.5 1879 7278 14.6 2032 100 100 0 10.8 84.8 20.7 1838 7293 14.4 2040 100 100 0 10.7 84.8 21 1908 7342 14.4 2024 100 100 0 10.7 84.5 21.1 1851 7407 14.3 2040 100 100 0 10.7 85 21.3 1879 7423 14.3 2049 100 100 0 10.7 85.7 21.4 1893 7457 14.3 2032 100 100 0 10.7 85.1 21.7 1879 7490 14.3 2066 100 100 0 10.7 86.1 21.7 1923 7490 14.3 434 76 100 0 10.7 16.3 21.1 181
Correct me if I'm wrong Mike, but to set it up right with that spring, he needs first to run a straight boost line from the turbo to the actuator. This way you know you are working off of spring pressure alone. Then keep tightening the actuator til it will produce about 15psi all by itself.
I set up the Forced Performance actuator on my WR in a similar manner on my car. However the FP spring is stiff as hell. I was informed to set it up to hold 17psi only on spring pressure. I had to cut my boost solenoid duty cycles in half (via Xede) as my first run I hit 27psi where it had been at 23psi on the OE actuator.
