sensor safe RTV
Old Oct 1, 2005 | 11:13 AM
nils's Avatar
sensor safe RTV
How bad is it to use non sensor safe RTV on a sensor?
Wondering if I should take out my Greddy oil temp sender and redo it with sensor safe RTV.
tia!!
nils
Old Oct 1, 2005 | 11:28 AM
sspeed's Avatar
Careful
Be very careful. Most over the counter RTV's give off acetic acid as they cure which wil destroy electronics and corrode bare metal. You need to find an electronics grade silicone material. These just give off alcohol as they cure.
Old Oct 1, 2005 | 12:17 PM
nils's Avatar
thx sspeed.
I put RTV on my senders after I torqued them in, so the RTV is not inside the thread. I used teflon for that...
the RTV only touches the outside of the sensor nut, nothing else...
should I still take them out and use snsor safe RTV?
Old Oct 1, 2005 | 03:11 PM
sspeed's Avatar
I would remove it... It is not the actual RTV that is corrosive. It is the byproduct of the cure (Acetic Acid) that is the problem. That is what you smell when you have uncured RTV.
babaz7
24
Aug 28, 2017 03:35 AM
evoniners
Jun 22, 2016 06:40 AM
kmartizdatruth
May 4, 2011 06:14 AM
vegasboy301
Sep 28, 2008 09:23 PM
nils
Mar 12, 2007 11:35 AM
