what spark plugs are you running?
Old Jan 10, 2010 | 12:26 PM
  #121
Kevin.'s Avatar
Originally Posted by cssaddictm4
What is most interesting in my research is the fact there are many plugs for the EVO8 but hardly any for the EVO9. I know it has been discussed that the EVO8 plugs will fit the EVO9 but I am not comfortable with that solution. One main thing is the reach of the spark plug for the EVO9 is considerably longer (it is called long reach). I tried using the EVO8 plugs myself and the spark plug boots did not fit/go all the way down. I am interested in trying 8&9 temps. I plan on calling NGK and Denso first thing tomorrow.
That's because this threads from like '05.
I'll be running BPR7ES's or BPR7EIX's.
Old Jan 10, 2010 | 12:29 PM
  #122
todd6027's Avatar
bpr8es here
Old Jan 23, 2010 | 05:29 PM
  #123
EvolutinIX's Avatar
I would suggest staying in the same heat range (7) with those mods. Go get some Copper NGK BPR7ES or Iridium NGK BPR7EIX. If you were running alky and 23-24psi daily, then I'd suggest you get some 8s (BPR8ES/BPR8EIX), but I don't think you need those right now and will run better on the 7s.
Right on target, you don't need colder plug right now it would probably decrease performance with what is done to the car right now.
Raceghost
Jun 9, 2016 07:27 PM
wolf213
May 16, 2010 05:43 PM
importjake00
10
Jan 30, 2008 05:31 AM
noriceoz
Lancer Engine Tech
14
Nov 7, 2004 06:43 PM
Quick Reply: what spark plugs are you running?
