Any TITANIUM Downpipes out there?
Titanium sucks for high heat. My dad flies turbine powered rc jets. They used to use titanium exhaust ducts for the turbines. Well my dad ended up burning a hole thru exhaust his turning his plane into a huge ball of flame. It was pretty cool but I learned a nice lesson that day
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
actually, titanium can be amazing for high heat....several cars come with titanium rods and surely the heat inside the engine is insanely high, and it is subject to enormous stress. It;s tensile strength is also amazing, which is why it is used in such high stress applications.
However, just because it is titanium means nothing...there is good ti and bad, just like good stainless and bad.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Did no one read the quoted text from Burns?
There are numerous kinds of titanium and titanium alloys, each with different thermal and strength properties, some of which CAN be advantageous for exhaust applications.
I have no idea what kind of titanium is being used in the APBoss downpipe, nor the A-Spec components, but I am sure (or would hope) that they are aware of all of this and havetaken into account when producing their components.
Pure titanium is very brittle. Thats why alloys are used that are less brittle. It is still more brittle than SS. It will be stronger and lighter if the impurities are kept to a min. SS will bend slightly over its limits before breaking. But Ti will just break when its limits are exceeded.
IMO there is not a drastic enough weight difference between a Ti and SS downpipe or even complete exhaust to justify the price and extra work necessary. There is a lot of stress on the dp from heat and movement/vibration of the motor that i believe SS would be better suited for a dp.
IMO Ti is more of a status piece in exhausts. The benefits are not great enough to justify a Ti exhaust.
Being that I used to fabricate the exit nozzles for the RB211 and V2500 lines (Rohr), I think I might know a little about Ti and heat. However there are many different grades of Ti like in any other modern metal used in current applications. For the most part, if you stay under 1780 degrees (if I remember right), you will get no alpha-case formation/degradation.
WTB[Northeast]: Titanium Downpipe
KamilEvolution
18
Jun 6, 2016 12:38 PM
Reign1nBlood
Jan 29, 2011 09:13 AM
REDEVILEVO9MR
21
Jan 29, 2007 09:27 PM
