fonky engine sounds
Old Oct 7, 2005 | 06:54 AM
mike1023's Avatar
fonky engine sounds
hey so this pass week i have been driving the car when i get on it and im in say high rpms. it sounds like if you have a bassball card in a bike and it makes the click sounds. and then i was trying other things. i was on high way and i left in 3rd and was at 5000rpm and was just a little on gas so no boost and the motor sounds likes that. but not as loud when on it. is this normal or what like its really not normal sounds. help help any resoning.
Old Oct 7, 2005 | 06:59 AM
gsujeff55's Avatar
Warrtalon, would you like to put your perspective in on this? LMAO
Old Oct 7, 2005 | 07:05 AM
Smike's Avatar
Not normal. You have an exhaust leak. Is this a stock exhaust or aftermarket?
Old Oct 7, 2005 | 07:32 AM
mike1023's Avatar
every thing stock. can it be the waste gate like open closeing or somthing with that
Old Oct 7, 2005 | 07:40 AM
SterlingEvo's Avatar
If you had an Elec. boost control I'd say you're hearing the stepper motor... it's a very rapid click-click-click-click-click-click-click-click-click-click-click-click
Old Oct 7, 2005 | 07:48 AM
Smike's Avatar
No. If it is a clicking or "phitt" sound that is repeating over and over (i.e. click, click, click, or phitt, phitt, phitt) then I would lean towards a small crack type leak in the exhaust. Check all connections - Turbo to DP, DP to Cat, Cat to Cat-back, and the muffler. Where is this sound coming from front (engine), middle (cat-cat back), or rear (muffler area)?
Old Oct 7, 2005 | 07:55 AM
mike1023's Avatar
deff in the engin pay it sounds like and on the right side. way can it be that line going to turbo the recall part. i dont think so. you dont think headers are cracked or anything. but it sounds more like its the motor it self. not the exhaust. i will cheack tho.
Old Oct 7, 2005 | 08:20 AM
Smike's Avatar
Ah, how bad/loud is it? Could be knock or worst case - mine you worst case - a bent rod or something else internal.
The recall on 05s was for a coolant hose that could break, (unless there is another one out there that I havent seen).
Does this happen at idle? Go to the engine bay and rev it up using the TB. Try to locate where it is at. If its under the valve covers then its engine, if its from the headers, could be the gasket.
Still have the warrenty? Just take it in to the dealer - given I dont like that option either, but they should cover it.
Old Oct 7, 2005 | 08:44 AM
mike1023's Avatar
humm this sucks. i dont hear at idel but i do hear like the valves clickin like crazy and when turn car off it like has werid click down too lol. edison nj maybe you can just lisson to it. this suck how can rod or anything be bent. i mean its 17k miles on a 5month old car.
Old Oct 7, 2005 | 09:14 AM
Smike's Avatar
I may be able to, send me a PM. Depends on the time and place. I have to drive to Philly for the weekend. You havent modded the car right? Id go in to the dealer.
Old Oct 7, 2005 | 09:16 AM
mike1023's Avatar
i have boost gage, turbo timer, and a utec but i have nothing done with utec becasue waiting for wide band and all that so i can start tuning. but i dont understand how this can happen.,
Old Oct 7, 2005 | 10:02 AM
Smike's Avatar
I have blown up engine before just from just driving. My 96 Impala SS had a manufacture defect in a bearing (LT1). The ended up freezing and that ending that engine. But as I said earlier - thats a worst case scenrio.
Old Oct 7, 2005 | 10:57 AM
mike1023's Avatar
well if a rod is bent wont the motor not go lol.
Old Oct 7, 2005 | 11:44 AM
Smike's Avatar
lol it will run but poorly and noisy. where are you from?
Old Oct 7, 2005 | 12:00 PM
mike1023's Avatar
new york, rockland area.
