EGT sensor probe keeps getting loose
The EGT sensor probe thats mounted on the manifold keeps loosening up after some time. Is there anything I can use so that it stays tight? Maybe thread lock, not sure if thats a good idea on the manifold that gets that hot.
Just a comment on thread lock or 'Loc-Tite'...... Don't use the green stuff unless you never want to remove it again.
I used some on the flange studs on my old T-3 setup on my honda, and all I can say is that it never came loose. After some time I had f*cked the threads up on the stud, and had to try and remove it. Drilled a hole in the stud and tried an ez-out, and snapped it off in the stud. Long story short, green 'Loc-Tite' is very strong and holds high temps.
GTVEVO
Aug 26, 2009 07:59 AM
krayzeviet
Automotosports - Illinois
Nov 27, 2006 01:37 PM
