Boost Spike!
#31
Originally Posted by 2literv8eater
I'm having that same spike due to larger flowing exhaust and stock boost control. Just ordered a Forge MBC.
Mine spikes to 22-24psi then drops to 20 psi for a sec and by that time the taper kicks in and it goes to 16-17psi, that's a big spread from high to low boost. MBC should fix it, I will post back when I get mine and put it on.
How much boost is safe to run with no tune and just a full 3" TBE? 20psi?
#33
20-21 is fine on pump gas.
