Vivid Racing Dyno Results
#46
Leave it to internet forums to start talking about lawsuits before all the facts are even laid out on the table... yeesh.
Let Mitsubishi take care of the situation (assuming there is one in the first place, of course). They have been incredibly responsive to all the info we have provided to them. They are really on top of their game. I'm sure they will do what they need to do in order to rectify any potential problem, global to the entire run or isolated to a small batch of cars.
FWIW, it's not unusual for issues to crop up a car's first year of production. It's happened to Mazda, Acura, Ford, BMW, Porsche, etc,. But once the problem is confirmed and an appropriate solution is determined, a polite little recall notice finds its way to the mailboxes of owners, asking them to drop off their cars to their dealership. The dealership is then instructed to perform the necessary work. And in very short time, the problem is solved and the customer goes back to enjoying their now-improved car. That's a lot nicer than getting all bent out of shape right now and making a stink about something that one isn't fully informed about.
Best Regards,
shiv
www.vishnutuning.com
Best Regards,
shiv
#47
oh no, the rest of the country other than California has the "ringers". Stop it guy!! Your expertise is not in question, however your ego has a need to deflate a bit. Tuner you are, but in this case you complained about hp deficiencies that clearly do not exist. Tuner you are--Lord of the tuners you are not. There is no way in hell that a 180 hp at the wheels will be able to propel a car to go 13.5 or better in the 1/4 mile. NOway!!!!!!!!! Maybe the case may be that west coast got humped by emmission detuning. The rest of the country is smiling . Our cars are going 12.7's with an air filter and a cheap old V-AFC. Good luck on promoting more mysteries and you being Holmes to solve them.
#49
Did it even occur to you that "Holmes," aka Shiv was the one that discovered that Mazda was overrating the Miata when it claimed 155 horsepower? I believe a little patience and courtesy is in order before mud slinging his way begins. At the very least keep an open mind and stop with the 1/4 mile posturing.
Brett.
Brett.
#50
180 wheel hp is is quite substantial on our dyno, btw, which should not be compared directly to the results of other dyno types. No surprises here. This point should hit home especially considering Turbo mag's recent dyno comparison formally illustrated the big differences between a number of different dyno types. Moral of the story: Not all dyno hp are created equal.
As for your 1/4 mile ranting, there is no question that a 180 wheel hp EVO (as measured on our dyno) is capable of running quite quickly as most of that power is made as early as 4800rpm. That's a lot more area under the curve than just about any other 180 wheel hp cars we've tested.
This, BTW, illustrates the inherent problem with deriving peak hp estimates from 1/4 mile results. .
Best Regards,
Shiv
#52
It's been clearly documented that 1/4 mile trap speeds correlate extremely well with horsepower numbers, more so than any other common measurement of performance. You can find these studies on the web.
I thought everyone had gotten past arguing about Shiv's dyno results. Shiv says he has the most accurate dyno type, and others say it underrates the horsepower. I personally think that his dyno underestimates horsepower, but the conclusion I've made is that we shouldn't take dyno results as absolute values. We should use the dynos as tuning tools to generate relative results as we tune the engines.
#53
I have no problem with the differences in different dyno but i do have a problem when this kit adds this much hp. If a tuner claims thier kits add 50hp and another tuner on a different dyno claims he added 50hp to thier kit. Which 50 hp is greater? This is important for us consumers and a time slip usually answers our performance questions.
#54
Originally posted by gtr
The problem with this thought is 1hp difference should be the same as 1hp difference on another dyno? I mean the mustang dyno claimed that the evo is 50whp greater than the wrx where as shiv's claim 20hp. So is if shiv's packages adds 20hp to his dyno meaning 35hp on another
#55
Shiv,
No comments here, just a couple questions. There was talk in a forum about the different settings between your's and Vivid's DynoDynamics Dynometer (based on different numbers, 188-9 vs 233hp (93 oct.)). You had said you were talking to the manufacturer and Vivid and that there would probably be a compromise between the two settings resulting in your numbers increasing and Vivids numbers decreasing (a little). What were the results or did I miss that part? This reply is not intended to degrade or imply negatively on either performance shop. Just asking if there was a compromise. I believe your talks with Mitsu can only help. Thanks
#56
Shiv's horses are just bigger than anyone else's.
By the way Shiv, when are you going to update your site? I want more scoop on "Phase II!!"
n8
Vivid Racing
EvoX 'For Sale' External Engine / Power
40
Aug 24, 2010 10:43 AM
Vivid Racing
24
Mar 24, 2003 02:16 PM
