New Dyno Results With New Toy - M A F Translator Pro
Last time I was on the Dyno I made 310awhp and around 300awtq. This was on a Dynojet. I had a few problems with a boost leak, plugs were gapped to wide and my MAF was messed up. I had screw driver slip and it broke a few honey combs.
Fast forward about three weeks later and I purchased a new toy. I got this new piggyback called M A F Translator Pro. This device claimed to be able to remove your stock MAF. It will allow you to use a GM MAF in a blow through configuration or run Speed Density using a GM MAP Sensor. I spoke with the guys who design the product and they said it should work on a EVO so I bought it
I received the MAFTpro on Wednesday and by Thursday at noon time my car was running. After going thru some options with some people on the boards I decided to remove the UTEC and get a reflash from Jestr @ www.jestrtuning.com. So on Friday I drove over to Orlando to get my car on Central Florida Turbo's Mustang Dyno. Jestr did not modify my cars AFR on the ECU side, he just removed the fuel/boost/speed limiters, raised my rev limiter to 8300 rpm, and adjusted my timing. All the AFR is set in the MAFTpro. Here are the results of about an hour and half on the dyno:
The unit looks really good for getting rid of the stock maf. You should definitely see a bigger improvement on a bigger turbo. I made similar numbers on that exact same dyno with the stock maf, but your power keeps climbing past where mine peaked. Again, everyone's cars are different. This unit does give you the ability to control your AFR. I really like the options that it gives you. Injector scaling is a huge plus. I may have to consider looking into it more before I go with the UTEC. Please continue to update us as you go along on how the unit holds up and its overall adaptability to everyday driving. You can check out my chart in the regisry here, click
Originally Posted by bpclements
The unit looks really good for getting rid of the stock maf. You should definitely see a bigger improvement on a bigger turbo. I made similar numbers on that exact same dyno with the stock maf. Again, everyone's cars are different. This unit does give you the ability to control your AFR. I really like the options that it gives you. Injector scaling is a huge plus. I may have to consider looking into it more before I go with the UTEC. Please continue to update us as you go along on how the unit holds up and its overall adaptability to everyday driving. You can check out my chart in the regisry here, click
Originally Posted by Creamo3
That is a nice option, can you direct me to their site. I am currently flashed and was wondering if you adjust your AFR through this device?
Originally Posted by joeymia
That dyno pull was from the last pull of the night. The car was very heatsoaked. My first pull when I get there was over 360awhp but trq was a little low. I am sure when I get a new FMIC and get the methanol going i'll be over 400. I had a UTEC before but I prefer this since Jestr is local. This has the ability to change to different AFR's on the fly when the methanol runs. It also has target AFR so if your methanol runs out you don't blow the engine.
so how user friendly is this unit. I have a works tune right now but man would i love to get rid of the maf. What was the install like was it just plug and play or did you have splice wires? Any other info would help to thanks
Just making sure that's 357/328 on a Mustang Dyno using 93oct WITHOUT the meth running, right?
Here is another picture of the MAP sensor.
That purple cable hanging on the harness is so you can switch fuel trims on the fly. If that cable gets energized it will switch to a different set of fuel trims. I will set it up so when my methanol pump energizes it will switch to methanol trims.
