WARNING! EVO Front Differential Issue?!
Originally Posted by joeymia
Are Quaife diffs still a pain in the *** to get? I was thinking of putting one in when i do a clutch swap.
http://www.roadraceengineering.com/evo.htm
P.S. I love you Mike W. and John M. !
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Originally Posted by ace33joe
Yeah, I would like to know what are the symptoms of this problem.
To check and see whether or not your front differential is broke where it plugs into the viscous coupling you needs to:
Have transmission in neutral
Have E-brake on
Raise car up on hoist
Now check and see if you can spin both front wheels easily in the same direction. Make sure you have the car in neutral and the E-brake on or this test won't work.
If the end snout is not broken viscous is working you will be able to spin them but it'll take quite a bit of effort.
If the end snout is broken it'll spin with ease.
Originally Posted by GEARS
The car would act like it doesn't have a limited slip/viscous coupling between the front and rear pinion shafts and the car would easily light up the front tires if you mash the gas in 1st from a 3000rpm roll.
Have E-brake on
Have E-brake on
Originally Posted by EVIL_EVO_VIII
Hey Jon, whats your opinion on the 05's lsd's? Are they strong as ppl say they are? Ive read somewhere that they are almost as strong as the quaiffe, this true?
We offer a 1 year warranty on them and can rebuild the unit for cheap if it ever wears out.
Jon@TRE
We haven't seen anyone break them but I'm sure there are some people on here who could break it and rightfully deserve to since they have to...
Jon@TRE
Jon@TRE
You guys offer the OE 05 LSD's now? I'm not a fan of clutch types in a daily driver, and have not looked to see what type the Ralliart is.
Could this type of failure be induced when launching the car off the apex berms at the track? This would send a shock load down the driveline even though a "drag" launch has not been done. Turn 15's berm at Thunderhill causes my suspension to bottom out if I hit it. It probably sends my front left wheel into the air too.
Originally Posted by Tsurara
RoadRaceEngineering has 20 in stock
P.S. I love you Mike W. and John M. !![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Originally Posted by roger smith
Yeah. 05's+ have helical front LSD like the Japanese ones have always had. The quaife is also a helical type LSD I believe.
03, 04 have VCU POS - Viscous coupling unit piece of s'
10, coupling, diff, differentail, differential, diffrential, evo, evom, front, installing, issues, problems, quaife, slipping, viscous
