shifting w/o using the clutch..
Old Nov 3, 2005, 06:35 PM
  #31
DragNRacing's Avatar
Try driving about 50 miles with no clutch because your throwout bearing cracked in half and the clutch won't disengage. Starting the car in first with the clutch permanently engaged bites the big one and reverse is about as much fun. Don't do it unless you have too.
Old Nov 3, 2005, 06:39 PM
  #32
Evoegg's Avatar
Originally Posted by MaxR
If you've got a cheeseburger in your left hand, the gearshifter in your right hand, and you're using your left knee to hold the steering wheel, then you have a perfectly good reason to shift without using the clutch.
Nah if you have a chick in between your legs ..... then you really dont have feet for clutch ...
my 2 cp
MalibuJack
May 25, 2017 06:46 PM
MitsQueen
Aug 20, 2002 12:30 PM
Quick Reply: shifting w/o using the clutch..
