how to install zeitronix zt2?
#31
Something is not correct. You should be able to view a/f already on the lcd. Sounds like you have 2 separate issues. After hardware, look at "ports", plug in the usb and see what port gets assigned to it. If higher than 4, then right click on it go to advanced and change it to a number, 1-4. Use this same number to set up logging in the zt2 software.
#32
So do you have a clue why the engine idling really low and will eventually stall?
trinydex - I tap the zt2 red wire to ecu pin#25 and zt2 black to ecu#26 and for the boost source, I tap the yellow-red, brown-black, and orange-green.
I'm just going to double check my wiring later and see what's up.
#34
Originally Posted by Eshark
Anyone have pictures of where they placed the lcd screen.
Thanks
Thanks
#36
I run my ZT-2 and my AFC off of the ECU power with no issues...I am pretty certain that is not related to your issue.
Originally Posted by AznFlip
Yeah, probably that's why. But I'm still having trouble finding my usb port #. I did what you told me, but don't which to click after Hardware.
ez- Yeah, I have LCD, I'm only currently reading boost and it's reading fine.
Oh by the way, I forgot to mention. After I installed everything, I started the car and it's idling bad. The engine just want to die. The car wasn't like this before I installed the zt2. I read somewhere that it sucks the power source from ECU, so I'm thinking of relocating my zt2 power source to the cigarrete lighter?
#38
It's possible. The only thing you really can do at this point is triple check (or redo) everything you did and then have someone else check it over it for you if there are still issues...
I guess it's my wiring...
#40
there are a bunch of other pics for zeitronix placement in the zeitronix install location ideas thread. very good pics that show you what's visable and waht's not.
as for aznflip, this may sound bogus but did you check your maf plug? cuz i know that it will idle funny and drive like crap with that unplugged.
#42
#45
I hope you mean that you are using a third O2 bung and not replacing or disconnecting a stock O2 sensor.
