how to install zeitronix zt2?
Old Dec 17, 2005, 09:26 AM
  #61
TTP Engineering's Avatar
I say you have those 2 connections reversed.
Old Jan 8, 2006, 02:12 AM
  #62
lagcisco's Avatar
I installed the boost sensor today but it reads boost as negative?
then goes into positive when I boost up..
is it ok to install the sensor inside the engine bay?
I didnt want to run the vacum line inside the cockpit
Old Jan 8, 2006, 02:30 AM
  #63
AznFlip's Avatar
all boost sensor/gauge does that.
Old Jan 8, 2006, 02:41 AM
  #64
trinydex's Avatar
this is known as vacuum. the car runs in vacuum around idle. this is becuase the movement of the pistons "sucks" air through the engine. only when you're boosting is air "crammed" in and pressure goes up.
Old Jan 8, 2006, 02:52 AM
  #65
lagcisco's Avatar
hey trinydex are you on socalevo by any chance? you're from LA right?
you answer alot of my questions
thanks.
Old Jan 8, 2006, 03:22 AM
  #66
trinydex's Avatar
yeah i am... but this forum gets so much more action... so i only go to socal every like few days. all the homies is there tho
Old Mar 24, 2006, 03:30 PM
  #67
trinydex's Avatar
[QUOTE=TTP Engineering]
Originally Posted by AznFlip
Can somone complete and correct this.
Zt-2 Pin #..............ECU Pin #
1........................25 YES
2............................ IN YOUR CASE, NOT USED.
3............................58 YES
4.....WITHOUT BOOST SENSOR= NOT USED -OUTPUT FROM BOOST SENSOR ORANGE
6............................81 YES
7............................26 YES
8............................92 THAT IS FINE
9............................... NOT USED
10..........................84 YES
11............................. WITHOUT BOOST SENSOR= NOT USED, WITH SENSOR=92
12............................. NOT USED IN STANDARD INSTALLATION
for 11 can you also make the boost sensor's black wire come in here?
Old Mar 24, 2006, 03:59 PM
  #68
Yes, sensor ground 92.
Old Mar 26, 2006, 12:40 PM
  #69
trinydex's Avatar
when installing hte safc the ground wires go in a certain order. when installing the zeitronix also... is there a similar order or a prefered order of ground wiring?
Old Mar 27, 2006, 06:55 AM
  #70
There is no order because the grounds do not go to the same place. Ecu gnd and sensor gnd are two different pins.
Old Mar 27, 2006, 08:38 AM
  #71
trinydex's Avatar
ok cool... do you happen to know why the safc has preference for ground? the brown wire has to be closer to the ecu? i'm just curious now.
Old Jun 20, 2006, 03:33 PM
  #72
justchil's Avatar
This thread was usefull for my install My zt2 only came with instructions for the warning box not for the main unit (unless I somehow lost them). Now if the screen came with a mounting bracket I'd be golden
Old Jul 22, 2006, 11:48 AM
  #73
nj1266's Avatar
Do you happen to have a boost log from your Zeitronix? Can you post it in *.csv or *.dif format?
Old Jul 22, 2006, 12:01 PM
  #74
His post was from over 7 months ago. The ZEITRONIX medical grade precision kavlico 3.5bar MAP sensor reads in both vacuum and boost.
Old Dec 1, 2006, 07:31 PM
  #75
LimPShoT's Avatar
Bringing this one back. Helped me alot on my install but was wondering where the Purple wire goes (pin 9) from zeitronix harness??
Quick Reply: how to install zeitronix zt2?
