LPH 255 or Walbro 255
Like I stated, we have installed over 50 pumps and the kits come with about 4-5 parts and the rubber lower insulator is the only one that you could possibly benefit from. Most Evo's are <30K mi. Mine @ 12K, pump went in at 2500mi. You do not need to replace your fuel pump screen with such low miles. Most pumps never fail or need a replacement screen and are good to 150K mi +.
Universal DSM kit contents:
Insulative sock= does not fit
wiring harness= does not fit
pump screen=why have 2, stock pump already has one?
screen retaining ring=why have 2, stock pump already has one?
insulative lower pump spacer- pump works with stock or walbro insulative spacer just fine.
So again, all these parts... Only one is useful, which is not even necessary= a waste of money IMO. I do sell these "kits", so buy them if you want to. Honesty is my policy. It is not needed IMO.
just a recommendation if you have a aftermaket fp then follow the directions and dont run it with less then a quarter tank of gas it is really hard on them. This will help prevent you from ending un frying two pumps in two years like some people.
Walboro all the way!!
Originally Posted by Zeus
I've killed my second Walbro 342 since purchasing the car in 2003. In the passed, these pumps have worked fine for me and my customers. Well, I took the plunge and have a 210 LPH Denso pump on the way. Even though it is listed at "only" 210 LPH... the graphs show it has an output of twice the OE unit. Whisper quiet too compared to the Walbro... but over twice the price
I bought the kit with my walbro pump. I don't know, I kinda like the stock setup at the pump outlet, vs. the smallish o-ring that comes with the kit. I used the new filter, but my old one didn't look dirty at all. But I scrapped the new o-ring and re-used the stock "hat" looking thing. It's gotta form a tighter seal, and not bypass fuel much better than a simple o-ring.
Originally Posted by 'ringmeister
-where were you able to order the denso? thanks
Most seem to be fine with the Walbro... I just want to "know" I'm set, and not have to hear it all of the time.
Originally Posted by AzBlackEvo8
Which one should I go for?
Seems like most ppl here have walbro
they're the about the same price
cheapest I found for walbro is $85 on ebay, is that good? Can any vendor beat it on here?
Thanks guys
Thanks guys
The kit is a waste of money. I do not make my clients pay for a kit they maybe will use one rubber piece out of. You can swap the filter off of the old pump and be done with it.
It definately wasn't a waste of money for me. I bought the whole kit from GSC for $80 because I stop by frequently.
I also used the two spare hose clamps supplied in the kit to fix my refrigerator water/ice maker line.
FS[SouthEast]: Walbro 255
hutch959
Aug 18, 2016 04:23 PM
hutch959
Dec 18, 2015 05:20 PM
