Cam Gains?
It all depends on the tune. And there really isn't much difference between all three while running the stock turbo. Once you go with a bigger turbo, then the 272 & 280's will get you some better numbers than the 264's.
I like the 264's because you don't need to get cam gears and there is virtually no difference in the idle compared to the stock cams.
You dont need camgears for any good cams... assuming they are close to the correct 'degree' from the factory. The only real reason you would NEED the cam gears is for a cam that needs to be degreed badly.
On low HP and stock rev limit you wont see any gains really. They will hold the power longer but it moves the power band much higher... so if your powerband is currently say from 4k to 6k aggressive cams could move it to 5k+... but if your turbo still produces power much lower and drops off up high it is pointless... you open the car up to more air in an area that the turbo isnt pushing efficiently anyways.
Look at the Buschur Stage 2 and Stage 3 numbers. Stage3 adds a FMIC and 264 cams.
320whp 329wtq for Stage2
348whp 329wtq for Stage3
Are you saying Buschur gained 28whp with just the intercooler? Doubtful.
I guess I worded it wrong... you wont see any power increase overall... you lose a whole bunch at the bottom and gain some up high. Think about it... the IC & piping gives 10 and cams gave 18... the IC didnt lose any power so the only power loss down low would be from cams. You need to look at alot more than peak power On top of that... if I do 4 pulls in 4 days... my HP will flucuate around 15-20hp. So what parts accounts for those gains/losses
I guess I worded it wrong... you lose a whole bunch at the bottom and gain some up high. Think about it... the IC & piping gives 10 and cams gave 18... the IC didnt lose any power so the only power loss down low would be from cams. You need to look at alot more than peak power On top of that... if I do 4 pulls in 4 days... my HP will flucuate around 15-20hp. So what parts accounts for those gains/losses
It is apparent that the cams lose power down low. Lets also look at the track times...
12.42@111 - stock cams (Stage2)
12.09@115 - add 264 cams and FMIC (Stage3)
Bottom line, cams help despite the gains on the top end only. GET CAMS!!!
My best friend Sergio(Evofunk) just had his car dynoed and gained 31WHP with Cams and LICP.
This was done at Precision Dyno. This is the thread:
https://www.evolutionm.net/forums/sh...d.php?t=167223
Definately you need cams. By the way, I gained 1.5-2mph higher steady tra speed on the 1/4 mile by just adding the Buschur Upper IC pipe and the AMS Lower IC pipe.
The one thing though is that his cams 264/272 sometimes gives him some erratic iddle issues(rpm fluctuations), something that the 264/264 would not give you.
I have 264/264 and the response is nuts. The car has absolutely no boost lag at all.
When I go from a roll at 50MPH I punch it in 4th gear, never in 3rd, I do the same in 5th gear at 70MPH instead of third gear..
Originally Posted by Insanenoodle
thanks for the quick response guys.. i just bought 272's.. now about the idle issues, will the crappy idle affect driveability (stalls easier, etc)?
I've never had any stalling issues with the cams, even b4 I had them tuned, but its a fact that all Evos are not created equal.
Jimmy242
Sep 22, 2005 07:56 PM
