anyone tried Redline MTL oil?
Originally Posted by djtmotorsports
I use a "cocktail" of 2 qts MT-90 & 1 qt MTL for all my EVO guys and have had great luck. BTW - The Redline engineers don't recommend straight MTL for our transmissions.
I'm not sure what they offer over there, but maybe look to what the asian/european owners use on their Evos to see what is compatible. Worst comes to worst... OEM fluids.
Originally Posted by WagsEvo
I have the same mix and found it to be a perfect blend. Like DJT said, straight MTL or MT-90 is not good, but a mix gets just the right weight.
I'm using the Redline cocktail that DJT mentioned. He told me he asked Redline about it and one of the engineers recommended that mix to him. I replaced the Royal Purple Synchromax I had previously and it's been good, after a track day and daily driving for about 5K miles so far.
If you read the Redline site... the MTL is recommended for areas with cold climates since it's slightly thinner than the MT-90, but I dont' think you want "thinner" viscosity with the Evo. That is one of the reasons why I switched from the Synchromax because I was told it's a bit too thin for the Evo trans, according to Royal Purple's site and recommendation.
This might help, too. Good luck in the research.
Red Line Synthetic Oil Corporation
6100 Egret Court
Benicia, CA 94510
PHONE: (707) 745-6100 or (800) 624-7958
FAX: (707) 745-3214
6100 Egret Court
Benicia, CA 94510
FAX: (707) 745-3214
Hi,
Just changed my transaxle fluid with Redline MT-90 straight for the 4th or 5th time (45k miles). Still on stock clutch and it feels great. I may try a quart of MTL next time, so maybe smooth it out.
I think the spec is for 75W-85, and MT-90 is 75W 90 while the MTL is 75W 80. Thus the "cocktail" is probably a little closer to the factory spec. My car still shifts pretty smoothly, esp right after the fluid change, but I bet it would be even smoother with the cockail. I used NEO RHD (GL5) in the transfer case and rear diff.
Good luck,
FB
Good luck,
FB
6100 Egret Court
Benicia, CA 94510
FAX: (707) 745-3214
6100 Egret Court
Benicia, CA 94510
FAX: (707) 745-3214
To specify, I first used straight MT-90 because I think the manual says either 85 or 90 weight. The shifting was so notchy I could barely put it into gear - especially in the winter temps. After a few weeks of that, I drained a quart and went with the cocktail.
If you are going to go stright with one fluid, use the -90, NOT the MTL. Hope this helps.
I went to the dealer the other day and I asked what they use for transaxle oil and he told he doesnt know. I told him to check and find out what brand they use. He came back later and told me all he knows is its 75W-90 and its for manual transaxle. I told him is it GL-4 and he said he has no clue because the bucket that they get it from has no label on it except 75W-90 on it.... WTF
Originally Posted by Derek888
thanks for help guys...
do you think its ok to mix GL-5 and GL-4 oil together?
https://www.amsoil.com/storefront/mtg.aspx
