really really odd problem
Old Nov 15, 2005 | 08:10 PM
Nad1370's Avatar
When you say " bone stock " currently. Was it modded before ?
If so, what kind of mods did he have on it ?
I was also thinking a small pin hole leak in the headgasket leaking in the combustion chamber.
Old Nov 15, 2005 | 08:13 PM
GPTourer's Avatar
If he was pushing coolant, he'd be seeing white smoke in his rear view while getting on it.
Old Nov 15, 2005 | 08:18 PM
Asta4125's Avatar
He took it to the dealer two weeks ago....they couldnt repeat the problem...prob because it was dropped off at night...and they didnt look at it till the morning, alowing the motor to cool down
Old Nov 15, 2005 | 08:19 PM
Nad1370's Avatar
^^ if it was a small amount . I don't think he'd notice it because it would have burned away in the cumbustion.
Old Nov 15, 2005 | 08:24 PM
Asta4125's Avatar
Ok....the car has 39k on it. He is the original owner, never been modded before. Only has a turbo timer on it. I am postive that its not burning coolent. The level is perfect. So i still am stumped. Its really odd, it doesnt do it on cool days or at night. But only on the hotter days. And never overheats while driving.
Old Nov 15, 2005 | 08:29 PM
mac_05evo's Avatar
air in the lines possibly??? (i'm no mechanic just making suggestions)
Old Nov 15, 2005 | 08:36 PM
Nad1370's Avatar
Alright,
I had a similar problem with my Acura integra. I found out that my fans were working but it started working when temps hit 220+ degrees.
Replaced the temp sensor and my fans kicked on 190 degrees. Fixed.
Old Nov 15, 2005 | 09:15 PM
Asta4125's Avatar
hmmm.....i will hook up a temp gauge tommarrow.... to see what temp they kicking in at. anybody know what the correct temperature is?
Old Nov 16, 2005 | 05:11 PM
TeamAccolade's Avatar
Originally Posted by Asta4125
Ok, im working on this guys 03 gsr. It currentally is bone stock. Hes having me do a lot of work to his car...gt35 kit along with the ams stroker kit...ect. But i really wanted to solve this issue before i started my tear down. So as i said the car is bone stock. It runs, and drives perfectally fine. On hotter days after ive driven the car. It begins to over heat. So for example. I drive, for lets say 20 min or so. Park the car for about 15 min, come back out, and start her up, and the temp gauge is reading past the half way point. Its not in the red or anything but it def is over heating. However once i start the car and get the coolent flowing, it drops down the normal operating temps. It has never over heated while on, even while sitting in traffic for hours, while its over 100. So this is something new to me that i havent seen yet in my days of builing motors. If anyone has a little insight it would be much apreciated.
its an 03.. there was a recall out on thier FCU fan controler unit... kept the evos/lancers/endevors from cooling properly... the fans just wouldn't come on... see ifs hes had that fixed yet.
Old Nov 16, 2005 | 05:23 PM
Curt@MrLed's Avatar
Former Vendor
you build motors and know nothing about this... wow.. its called heat soak. its very simple, motor isnt running, water not circulating, temp builds from the heat in the block... hence higher water temps... when you start the car, the thermostat, sense's the heat and opens instantly... there has yet to be a vehicle that doesnt raise the temp at least a little... even audi's raise, but only a little cause they run an external pump for the fluid to keep it circulating when the motor is off... also mitsu isnt like audi, the engine fan doesnt come on like an audi when the key is off.. otherwise an audi would do the same thing..
Old Nov 16, 2005 | 06:18 PM
ev-slo's Avatar
Harsh but true. No-one is perfect. Mistakes can happen. Nobody knows everything. I built my chevelle from frame up. I thought i knew that car inside out. A guy looking at it one day in the parking lot(thought he was trying to steal it) Spit out a crazy chain of numbers for my rear-end. I was confused. He wrote it down. Let me tell you, it doesnt stick to the ground for **** anymore AND I LOVE IT. Spinning in 5th gear is something to be proud of.
Old Nov 16, 2005 | 06:23 PM
zlancer's Avatar
yup its normal.
Old Nov 16, 2005 | 08:29 PM
elhalisf's Avatar
i have this very same problem in my galant vr4. it turned out to be the temp sensor in the thermostat housing. try changing that, or swap it with one from another car
