Why am i running out of fuel?
Should i be running out on injector this soon? My boost it rangeing from 20-21 psi and at 6k rpm my injector duty cycle hits 97%.
Mods 03 Evo
helix downpipe
helix testpipe
Jic Bullet ti cat back with the taper replaced with full 3"
Custom AL IC pipes (upper @ lower)
Custom intake with 4" inlet k/n filter
Custom FMIC (garrett bar/plate core 20"/12"/3")
Tial BOV
Wallbro 255
NGK BR8ES plugs ( gaped @ .026)
Autronic PnP
Timing is 18 deg full advance
I think thats all that will make a difference, but I have stock cams, turbo and injectors
I have 2 buddies with similar mods but stock front mount and 1 has 264's and dynoflash bpr7es and the other has 272's and SAFC, br8es plugs neither of them are having problems
Mods 03 Evo
helix downpipe
helix testpipe
Tial BOV
Wallbro 255
Autronic PnP
Originally Posted by erioshi
I've seen at least a couple of weak stock fuel pumps at dyno/tuning days. Going to a Walbro usually solves the problem.
Ive had a wallbro 255 in my car for over a year. If you would have read the mod list you would have seen that
d'oh - my bad; I guess I shouldn't try posting after returning from a night out! Any chance you can test with a different Walbro? While not comon, it wouldn't be the first time I've heard of one having problems.
for some reason, before i got my walbro, i was hitting 116% injector duty cycle on my car...and all i had done was an aem ems, boost was about 23-24 psi, 3" TBE, an ams LICP and i think thats it, i immediately ordered the walbro fuel pump and havent raced it since, so i dont know what the hell my injector duty cycle is, and i dont have the laptop constantly hooked up to check it
Well i think it has more to do with fuel pressure and the wallbro pump. my car will run 11.2 up until 6k hits 97% injector duty cycle and just stays there and gets leaner. I add more fuel and it really does nothing. Im going to get one of my buddies 255's and see what happens. this was just a weird occurance. My last wallbro just quit and stoped working. Ive never had any problems until this past week. all i did was switch from a bpr7es plug to a br8es i guess its giving off a better burn rate
a lot of people will tell you to upgrade your injectors once you you get much over 80% idc
90% is pretty much to much.
but the real question is where is all that fuel going. with those mods, I don't understand how you could hit 80% idc. have you checked your WBo2 lately? might not be calibrated correctly.
FS[Northeast]: [PA] Yellow Buschur Built Evo 8 LOW MILES - Great build
EVOlunchbox
For Sale - Cars For Sale
Feb 2, 2016 08:20 AM
Ralliartize It
41
Jul 1, 2012 09:28 PM
StreetThisEvo
Aug 4, 2009 12:04 PM
evovette
Sep 25, 2006 07:09 AM
