JEBUS CHRISTOS!!! Loud whistle!! HELP
Old Nov 20, 2005, 11:25 PM
akunochi's Avatar
SO I changed my clutch from stock to ACT HDSSw/ Super street disc. Now for the first 100miles of my break in the car was normal. Almost exactly at 150miles the drivetrain is creating this unbelievably loud winding/whistleing sound. I checked the fluids on the transfercase they're fine. Anyone have any suggestions on this...and by loud I mean like emergency broadcast loud.
Old Nov 20, 2005, 11:28 PM
EVIL_EVO_VIII's Avatar
Sad to say but it sounds like your transfer case is gone! What kind of fluids were put in the transfer case after install?
Old Nov 21, 2005, 04:50 AM
akunochi's Avatar
Royal Purple.
Old Nov 21, 2005, 04:51 AM
akunochi's Avatar
Also if the t-case was gone wouldn't the car drive/handle funny? It is driving and handling fine.
Old Nov 21, 2005, 05:19 AM
Rez90's Avatar
it's most likely a boost leak. Check your intercooler pipes especially the one that comes right off the turbo. I had the exact same problem.
chances are it's not your clutch at all....just a loud whistle from one of your connections.
hope that helps
Old Nov 21, 2005, 05:25 AM
evo 8 ya's Avatar
hope that helps
ah Boost Leak, the Evom universal answer for everything.
My bet, it's you t-case. There will be no difference in how the cars drives, just a loud noise when driving.
Old Nov 21, 2005, 05:40 AM
Rez90's Avatar
Insulting another member is not allowed.
Old Nov 21, 2005, 08:30 AM
The only time the car would drive diferentyl with a blown tc, its when the front diff has been blown, this can be felt when making left or right hand turns.
I his case, the fluid ****ed up the ring and pinions in the tc, hence why the tc is whinning.......Ive riden in an Evo with rings and pinions messed up due to the wrong fluid and it was LOUD!!!! It was a loud whinning like you describe. Call Jon at TRE or email him, he can answer that for you better. www.teamrip.com
Old Nov 21, 2005, 11:49 AM
akunochi's Avatar
I used this in the transfer case....
It only has 148 miles on it since the fluid went in, can I save it?
Royal Purple Synchromax Gear Oil
Old Nov 21, 2005, 01:10 PM
What r the specs on that oil?
Old Nov 21, 2005, 01:59 PM
blink2824's Avatar
I got my clutch installed and they tightened up my dp too much when putting it back on and bent the butterfly things on the ends of where the dp ends. It caused a massive boost leak and a really loud whistle under boosting conditions.
Old Nov 21, 2005, 02:37 PM
matt55's Avatar
NOooooooooooooooooooooooooooo
Old Nov 21, 2005, 02:55 PM
redman012's Avatar
Yah, no GL 5! Cause of the brass parts. I asked mitsu along time if GL 5 was ok just to see what they would say. Yah sure it will work! I won't let them even put air in my tires.
You should have looked or checked first. I hope everything works ok.
Old Nov 21, 2005, 06:38 PM
JSYEVO's Avatar
was it supposed to be 75w90?
Old Nov 21, 2005, 06:52 PM
matt55's Avatar
Mitsubishi GL5 LSD Gear Oil Diaqueen .
Quick Reply: JEBUS CHRISTOS!!! Loud whistle!! HELP
