Exhaust leak (o2 housing and downpipe)
so i was wondering how much it would effect my car if i had a small leak between my streetactionmotorsports o2 houseing, and my buschur downpipe.
im missing the rubber donut gasket, hopefully i can find one somewhere and not get ripped off at mitsu... so do you guys know if with that gasket, it will stop the leak?
also i was just wondering how much it would retard performance.
thanks in advance
thanks in advance
i dont think its a rubber gasket, but having a leak on a turbo car isnt that bad... i mean it just means the gases have a faster way to escape rather than going all the way thru the exhaust...
thanks in advance
thanks in advance
some gasket will fix the leak
and if it does retard performance it wont be much or even noticeable
exhaust leaks will spike AFR readings if you have a wideband.. that might be what someone told you.. I havent heard about actually running leaner cause of an exhaust leak. Not sure though.
n
n
doesnt the bushcur dp have a flat flange not a donut flange? if im correct (same dp i saw) then on my friends evo we took off the donut flange and just put a 3 inch flat 2 bolt and it worked awesome...
17579EVO9MR
13
Oct 26, 2010 12:53 PM
